Sub 8 mins on Nürburgring
02-09-2015, 05:55 AM | #1 |
Rep 2,343
Have you guys seen this?
http://www.topgear.com/uk/car-news/s...ack-2015-02-09 As far as I can see an E92 M3 has a lap time of 8:05. I'm not sure what kind of a time a FBO 335i might be able to post. Is this a case of a light car that's good at braking and cornering or did they have some superstar driver to get this time? |
02-09-2015, 07:07 AM | #2 |
Rep 686
All the OEM cars that boast these lap times will have specialist drivers either current or ex-racers or simular. It will also be a case of optimum track conditions the of the did the test on the same day the renualt still may have the quicker time? Im sure they do control the test enviroments to certain extend in terms of timing and runs and tyres etc but you cant control temperature and weather.
Small a light will help round the twisty stuff as it will get from point to point quicker whereas the heavier M3 will be marginally slower but would breeze past once its stretched it legs |
02-09-2015, 09:43 AM | #4 |
Rep 2,337
Those times are slow and very old. I think 7:50's have been done quite easily an e92 M3.
You don't want to be the guy that wrecked a brand new BMW on one of its first drives :P |
02-09-2015, 09:51 AM | #5 |
Rep 2,337
RS4/RS5 times recorded after than "official" M3 time are 10s faster. Now we all know that is unlikely!
This guy has done a 7:36. Slightly modified, but I don't think to the tune of 30 seconds. Tyres are the biggest difference I think though. Unless you do all cars on the same day it is hard to compare. |
02-09-2015, 09:54 AM | #6 |
Rep 3,295
The current range of mega hot hatches look really really good fun, the Megane R I believe current holds the FWD ‘ring record at 7:54, which is really quick.
http://www.evo.co.uk/news/evonews/29...wd_record.html But these things are pretty bare, stripped down for light weight, Ohlins dampers, LSD, massive brakes, lighter battery, power to weight ratio 230 bhp/ton which isn’t far off a M3. I use to a have Honda Integra R, which was the best of the previous gen of hot-hatches, had no radio/air con/minimal sound damping. Despite it only having 180bhp, AutoCar time it hitting 60mph at 5.5seconds!! Driving it was amazing, the steering was almost telepathic, and around a twist B road it really was unbelievably good fun… But I sold it after 9 months, because sitting in a traffic jam on the M1 in a car with no air con/radio is not much fun, no matter how light weight/responsive the chassis is. I went to look at a Megane 265 before I bought the 335i, 10 seconds spent sitting in the car reminded why I sold the Integra R, I didn’t even bother to wait for the sale man to come and talk to me. As a weekend toy I think these stripped down FWD hatches are great, but a day to day car, they are too compromised for a old man like me Personally I rather have my 335i, which gets through a 200 mile grind on the M ways in plenty of luxury and comfort, but come Sunday morning can deliver 90% of the fun of my Integra R. Last edited by gangzoom; 02-09-2015 at 09:59 AM.. |
02-09-2015, 11:31 AM | #7 | |
Rep 2,343
I have a question for you actually regarding the aftermarket LSD for the 335i and I hope it makes sense. Being that this is mechanical, will the LSD cut in before the single push DTC? i.e. Will you see less traction control cutting in with the LSD than without it or will the LSD really only be noticeable with the DTC/DSC fully off? I realise that for a power slide all nanies would have to be off or DSC will start breaking on individual wheels. I just wonder if normal driving with DTC single push on is also better. I suspect it is. Thanks |
02-09-2015, 01:52 PM | #8 | |
Rep 3,295
The Quaife LSD seems to work beautifully with the DTC/DSC, single press still allows for some tail out action, and fully off is what you would expect. Not sure exactly how the electronic and the Quaife work together, but it does....As Chris Harris points out, its almost as though some people at BMW wanted to fit a LSD to the 335 stock http://www.birdsauto.com/editorial/e...35i-april-2007 |
02-09-2015, 07:52 PM | #10 | |
Rep 2,343
Must be great having the LSD. I often see the TC lighting up on the uneven corners like you say. I also get it alot even in a straight line with these cold wet days and the roads covered in dirt. The grit from these lorries salting the road makes it very slippery at times. It has been fun on these ice covered roads but I can feel a slide is not quite right with the open diff. The snap back is too aggressive. BMW would definately want the LSD in the 335i if it wasn't for the M3. With the N54 twin turbo power plant they were already eroding M3 sales for sure. It was just too good as the 1M, new M3 and M4 have shown. |
02-10-2015, 09:13 AM | #11 |
Rep 3,312
Weight is the biggest killer to lap times etc hence that Sub8 is a costly weight reduction to help achieve the time that was set. This is usually the case with most of the manufacturers as they start to remove bits to provide the reduced lap times and quicker car.
As for the lsd on the 335i, straight line it does nothing for cutting the dash from lighting up with the traction light bug it does start to become more advantageous round bends. I've got full birds suspension upgrades and the Quaiffe but I still spin up the rears when booting it.
02-10-2015, 10:14 AM | #12 | |
Rep 2,343
02-10-2015, 11:01 AM | #13 | |
Rep 2,337
With an LSD when one wheel spins, more power is directed to the wheel with traction up to usually 30% slippage or something. |
02-10-2015, 11:28 AM | #14 | |
Rep 3,312
02-10-2015, 02:07 PM | #15 |
Rep 3,295
A previous European forum member had the ultimate 335i, LSD, ohlins suspension, hybrid turbos, BBK, custom made aftermarket oil cooler, and his 335 go well used/abused on the 'ring.
His done some fab write ups which is well worth a read. I've bought my Procede tune off him when he was getting rid of the 335i. For newer forum members his posts are worth a read, and shows what can be achieved with the 335 given enough effort...and it's not all just about chasing BHP I nearly met up with him last summer when I did a tour of the swiss alps in the 335i, my favourite line is when he is asked the question why he didn't get a M3 instead of tuning a 335i....his reply is simply, a M3 isn't quick enough http://www.e90post.com/forums/showthread.php?t=379776 http://www.e90post.com/forums/showthread.php?t=792844 http://www.e90post.com/forums/showthread.php?t=322185 |
02-10-2015, 06:43 PM | #17 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
Plus one on Marcel's write ups!
Tony's ones are also very good! |
02-11-2015, 04:23 AM | #18 | |
Rep 2,343
02-13-2015, 06:03 AM | #20 | |
Rep 125
It sounds like you had a import DC2 as AC and radio were optional over there. But standard on the UK integra and the later DC5. They also did a SIR which had less power but more toys and sound deadening. You are right in that they are more of a weekend car. In fact, there isnt another car ive driven that Ive had more fun in, it was on par with a Caterham I drove. i dont think the 335i comes close. I managed 8:45 with a standard DC2 at the Nurburgring on my first trip BTG. |
02-13-2015, 08:36 AM | #21 | |
Rep 3,295
When I eventually get a house with a double garage I'm going to buy another one, and keep it for the weekend. I was just too much of a girl to use it as a day to day car. Last edited by gangzoom; 02-13-2015 at 10:09 AM.. |
02-13-2015, 10:03 AM | #22 |
Rep 125
They are not for the faint hearted, must say Im not usually a fan of red cars but your Milano looks
Becoming more and more difficult to find a decent one now with decent mileage. Back to the topic- I think you would struggle to acheive a sub 8 min lap. Although it has the power for the Dottinger and Kesselchen it would struggle with braking and cornering. |
