View Poll Results: Which Color reflectors should I go with? | |||
Body Colored - Alpine White | 10 | 47.62% | |
Diffuser Colored | 11 | 52.38% | |
Voters: 21. You may not vote on this poll |
02-16-2015, 03:25 PM | #1 |
Rep 164
Opinions Please: F32 MSport rear reflector color
Swapping out the front reflectors for painted Alpine White was a no-brainer. As for the rear reflectors, I am having trouble deciding whether I like painted body-colored reflectors or those painted to match the stock diffuser. I've seen discussion in other threads on the F30, but given the different styling of the F32 in the rear, it's not quite as clear-cut for me.
My 'shopping skills are elementary-level at best, so the mockups below are crude. Images below are stock, body-colored, and diffuser-colored. Appreciate your thoughts.
'25 X5 x40i /// Oxford Green on Extended Tartufo
BUILD STATUS 112 ________________________________ Past: '14 Dinan4x /// BUILD THREAD |
02-16-2015, 04:08 PM | #2 |
Rep 17
I have an F30 and just finished my IND Alpine White front reflectors and opted to go with Dark Shadow Metallic (Diffuser color) on the back. The 4 series backend is a little different and I like your idea to do AW body-match, but there's something cool about making your rear bumper/diffuser look taller. I say match it to the dark diffuser.
Current: 2015 335xi 6MT MSport MPPK MPE Alpine White MPerf Alcantara/CF Interior & Alcantara Wheel
02-17-2015, 10:21 AM | #5 |
Rep 3,089
I am going to change my vote...I say body colored or leave it red. I like how it makes the shape of the diffuser even more pronounced. In the case of Neb3series, going diffuser colored actually accentuated the shape of the diffuser since the bumper on the 3 is different than on the 4. Its reverse in shape. Getting diffuser color on the 4 would make the diffuser top edge look like its going just straight across which to me is kind of uninteresting.
02-17-2015, 10:54 AM | #6 |
Rep 826
Drives: G80 M3 & G87 M2
I vote white Gives the diffuser a more pronounced shape.
Carbon fiber for the everyday driver: rwcarbon.com 3941 E La Palma Ave Anaheim CA, 92870 info@rwcarbon.com / (714) 328-4406 Instagram/Tiktok/Facebook: @rwcarbon |
02-17-2015, 11:37 AM | #7 |
Rep 149
Drives: 435ix,GTR, Huracan Performante
02-18-2015, 09:33 AM | #9 | |
Rep 17
Either way, taking out that orange up front and the red in the back will make your 4 series pop, especially to those who know BMW well.
02-18-2015, 04:28 PM | #12 |
Rep 3,089
Perhaps a silly question...why would the reflectors stop someone from hitting your car? I figure if they cant see a big stationary car, they wont be able to see two small reflectors.
02-18-2015, 04:29 PM | #13 |
BMW Fanatic
331
Rep 1,076
+1
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
02-18-2015, 07:29 PM | #14 |
Rep 164
Thanks to everyone for contributing thoughts. I've decided to go with body-colored given the "sculpted" bottom edge of the reflector and how it ties in to the associated body line. "Opposite if the F30" as was commented above. Appreciate all input.
02-18-2015, 07:54 PM | #15 | |
Rep 32,881
Being realistic, it is unlikely to happen i know, but on roads with no lighting and/or in fog they might just make the difference, it is why they're fitted to car after all. |
02-18-2015, 08:00 PM | #16 |
Rep 1,113
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
02-18-2015, 08:43 PM | #17 | |
Rep 3,089
Btw, I want that M4 spoiler for my F36! ^^^^^^ |
03-11-2015, 06:52 PM | #19 |
Rep 164
"After" pic below. Went body-colored to take advantage of the bottom reflector edge's contour. Thanks to everyone for thoughts and opinions.
-B
03-11-2015, 06:55 PM | #20 |
Rep 3,089
Nice! Any pointers on how to remove the reflectors?
03-11-2015, 07:03 PM | #21 |
Rep 164
Sure!
You can access the center clip of the reflector from underneath. No need to remove the diffuser or anything crazy like that. I scooted underneath on a creeper, and used a regular flathead screwdriver to push the center tab up so it's not "hooked" over the lip's edge. From there, I just pressed the tab relatively hard from the back side and the reflector popped out (May have needed to reach around with my other hand to pull from the outside as well; can't recall as they came out fairly easily). Once you have the reflector out, you'll see a total of three tabs. One of them has a hooked face on the side. To pop the painted replacements in, I put the hooked face (vertical "tab") in first by angling the reflector a bit, then just popped it in. The hardest part was maneuvering the creeper to get my hand through the tight spot to get to the center tab. All tolled, it took me 5 minutes - including time to find a screwdriver in my train-wreck of a garage. Hope that helps. If you run into trouble, feel free to PM me. -B
