04-05-2015, 12:48 AM | #1 |
![]() ![]() ![]() 3724
Rep 9,783
Are Porsches reliable?
Thinking about getting a used Cayman S and was wondering if Porsches are reliable. I read somewhere that Porsche is one of the most reliable brands but would like actual opinions. TIA!
04-06-2015, 08:28 AM | #2 |
![]() 476
Rep 928
Porsche is surprisingly reliable and I'm considering a Cayman or a 996 in the near future. The only thing I recall being a real issue with a 996 were the IMSB's going bad and were somewhat notorious for going bad, however I don't think this transferred over to the 3.4L in the Cayman.
The only real issue I've heard of in Caymans are oil ingestion and oil starvation and the engines will go from connecting rod bolts. The design causes them to expand over time and end up snapping, so if it's going to be tracked, I'm pretty sure there are companies that have aftermarket, but you need to take the whole motor out if I'm not mistaken. I think if you just use it as a street car you'll be fine, but if you abuse it, I'd expect some money being dropped into the motor relatively quickly. If you go over to planet-9, there's a ton of info. A little bit too much to take in at one time. |
04-06-2015, 08:51 AM | #3 | |
![]() ![]() ![]() ![]() 426
Rep 841
WHO'S THE BOSS
04-06-2015, 09:46 AM | #4 |
![]() ![]() ![]() ![]() 676
Rep 855
In similar fashion to BMWs, they are very reliable for 90% of owners. However, you definitely do not want to be in the bottom 10% as repairs can be seriously expensive if something does fail.
04-06-2015, 09:51 AM | #5 | |
powerhouse
![]() 742
Rep 1,628
Drives: 2014 Porsche 981 CS
no signature. except for this one.
04-06-2015, 09:55 AM | #6 |
![]() ![]() ![]() 11712
Rep 11,178
I know people get tired of hearing this, but I say to always make sure you buy a car with a warranty and you won't have to worry about them being reliable or not. Of course, if you're buying an older one which has high miles and no warranty left, then you might want to get a pre-owned inspection. And make sure the car you're buying has full service history. Then just put money aside each and every month for possible repairs down the road.
04-06-2015, 10:00 AM | #7 |
Rep 855
Sadly that seems to be the case. My 4 year old 1er has been in the shop more in the 2 years I've owned it than even my 20 year old RX7 turbo was over 6 years. That's not a good sign.
04-06-2015, 10:06 AM | #8 | |
Rep 9,783
Than BMW. |
04-06-2015, 10:10 AM | #9 |
![]() ![]() ![]() ![]() ![]() 137
Rep 638
There's gotta be a reasons why 90% of the cars you see at HPDE events are either BMW or Porsche. Sure, the "performance" matters, but I think reliability does just as much, if not more. Cars like Evo, STi, or Merc? Oh forget it.. we start betting on those.
I have rarely seen modern, relatively-stock Porsches fail at the track. And I also have a '98 Boxster with 140k miles without IMSB upgrade that has given me zero mechanical problems. By far the most reliable car compared to my several other BMWs, Hondas, Toyotas, Volvo, Mitsubishi, etc. But then again, I'm only 1 data point, so YMMV. |
04-06-2015, 10:20 AM | #10 | |
![]() 476
Rep 928
I'd just make sure you have history logs from any previous owner and find out what the car was used for, especially being a P car. If it was someone using it as a weekend car, I'm sure you'll be just fine, but if it was used for other purposes, I'd be much more leery. |
04-06-2015, 10:31 AM | #11 |
![]() 147
Rep 129
I had a non S Cayman. Zero issues with it other than it had no legs at all. Glad to hear you are looking at an S. Car handles great but to be honest I would look at a used 997. Just a personal preference.
04-06-2015, 12:00 PM | #12 | |
"Salud"
15510
Rep 5,067
![]() Quote:
I have a vehicle that is one of if not THE most NOTORIOUS for foking up out of warranty! Guess what? I'm out of factory warranty... And it has! BUT... My out of pocket cost for repairs was FAR less than ANY available extended warranty out there! Here's a breakdown: The absolute cheapest for my car was @ $5k. I have spent maybe a grand on repairs. Now I will say that initially, I paid out of pocket $2k for injectors. But BMW reimbursed me under a specific Customer Campaign. Lucky? Maybe. But even then I would be MUCH better off than the initial $5k! And before my F01 I owned two e65 7 Series. Both had factory warranty initially but that ran out and I ended up spending @ $1,400 on one and $2,500 on the other for timing chain. Guess what? The extended warranties were $4k had I bought them. But instead I pay from my own savings should the need ever arise. Also, I don't believe in buying high-end cars brand new. Meaning any car that has a MSRP over say $75k, I'm buying pre-owned all day every day! No way am I taking that 20-30% depreciation hit that continues each year. Fok that! I wait @ 2-3yrs and save @ $25k-$50k (as I have several times) and have a ultra clean, low mileage well pampered car that I own (keyword) and can turn around and sell at a profit (depreciation adjusted) and grab another $100k car until I'm ready for the next. Not saying everyone should follow my example, but it damn sure works for me. I too am considering a gently used, low mileage 997 and will save tens of thousands in the process. ![]() Oh and good luck OP. I think you'll be just fine. ![]()
04-06-2015, 12:04 PM | #13 | |
"Salud"
15510
Rep 5,067
Here's the article from above:
04-06-2015, 02:38 PM | #15 | ||
powerhouse
![]() 742
Rep 1,628
within the first few months of owning a porsche, i brought it in for scheduled maintenance and had to pay a few hundred just for the oil change. long story short, they all get their money one way or another so people should just get what they enjoy. since i drive more for fun than necessity; if ppl are looking at reliability because they don't want to get stuck on the side of the road then that's a different story. the question should be about companies like AAA, always bring a fallout bag, and maybe have more than one car.
04-06-2015, 02:47 PM | #16 |
![]() ![]() ![]() 59
Rep 345
I owned a used boxter S(RS60) and never had an issue while owning for 2 years. the only thing I paid was the $200 oil change by the stealership which I beat the crap out of their loaner
04-06-2015, 03:02 PM | #17 |
![]() 1934
Rep 3,040
SOME porsche's are extremely reliable. A 2009+ base or S model 6-speed Porsche boxster, cayman, or 911 is extremely reliable. Others are less so, and the ~2009 model year introduced direct injection engines that solved alot of problems for Porsche engines that existed since 1997.
Porsche is also very DIY friendly and a base model 911 is, generally speaking, not a super expensive car to own for a DIYer. Oil changes, brake pads, spark plugs, normal sensors - all pretty straight forward and parts readily available on Pelican Parts. Now if you are the type who just wants to drop it off at the dealer and not think about it, you will get gouged. ... A note on aftermarket warranties: I've had two warranties through route 66 (available through penfed financing). My first warranty cost me ~$1400 and covered around $5k in work the first year - then I sold the car and transffered the warranty. They provided quick coverage too. My second warranty is on my 08 535xit and cost $2k. It's less than 1 year old and covered about $400 in work so far. The warranty does not cover diagnostic cost and has other carve outs, but it is a good warranty and company. |
04-06-2015, 09:15 PM | #18 |
![]() ![]() ![]() 66
Rep 520
They are known to be reliable that is for sure. Cost of ownership is definitely not as bad as some of the other car brands in their segment. I will second what some others have said and say that buying a used car with a warranty is the best way to go. Obviously, this means one of the newer model years and will therefore be more expensive. That being said you will find tremendous savings in the used car market for Porsches because of the ridiculous cost of their options. If you are going to use the car as a DD and not as a track toy you will be in pretty good hands with a Porsche. Just make sure to get inspection before you buy (especially if the car is out of warranty). Good luck in your search!
2017 R8 V10 Plus, 2016 Boxster GTS, 2015 Macan S, 2015 V12 Vantage S - Pending Sale, 2013 911 C4S - Sold, 2012 V8 Vantage S - Sold, 2013 DB9 - Sold, 2011 997.2 Targa 4s - Sold, 2011 E90 335i M-Sport - Sold, 2013 981 Boxster S - Sold, 2006 E46 M3 - Sold, 2010 E60 M5 - Sold, 2006 E46 M3 - Sold, 2011.5 E90 M3 - Sold, 2006 325i - Sold, 2004 Mazda6 - Sold
04-06-2015, 09:36 PM | #19 |
Rep 9,783
Thank you all for your comments! I will keep an eye out for sure. It's between a used Cayman S or an M2. I would like to do ED with a Porsche but I don't know if I want to pay that kind of money for a new one.
04-07-2015, 08:50 AM | #20 | |
Rep 11,178
04-07-2015, 12:05 PM | #21 |
Rep 345
well you technically paid when you purchased the CPO warrantied car. A NON CPO is uslly 2-3K cheaper
04-07-2015, 12:13 PM | #22 |
![]() ![]() ![]() 1748
Rep 14,825
Honestly, when you're rich, it's not a big deal (most of us are not). Nobody likes to pay for s*** breaking, but think about it, how many people do you know, they lose their iPhone, and they're not worried about the money. They're worried about being unreachable, so they have an assistant run to the mall and get a new one for $929 plus tax and feel relieved once it's back in their pocket.
I have gone to the Porsche launces of the boxster and prior to that the 991. A guy told me the sweet spot in his opinion is 4-5 y.o. because many cars are not driven a lot. He said he has owned 2 new, and 3 used. And yes they are known to be reliable in a general sense.... |
