Ideal N52?
04-13-2015, 09:03 PM | #1 |
Rep 88
Ideal N52?
Just thinking up pipe dreams here...
I think it would be really cool if AA did end up coding for/making cams in addition to the headers and 3 stage tune they already have. Perhaps it would require beefed up injectors, but that would probably be possible considering that ESS has made some for their VT1+ kit. That would probably leave these motors (particularly the 215hp 3.0l version) with a lot more power. From there, a 6 angle valve job along with race gas, perhaps Dinan's ram air and MAF would make it quite a potent powerplant for the track with beefed up cooling. This is probably cheaper than getting an N54/N55 track ready and maybe better suited for the job. However, if AA doesn't end up making cams, it would be incredible to see a stroked 3.2l N53 with the ESS supercharger. The N53, being DI and without valvetronic, could be easier to modify with the realistic possibility of euro E36 M3 ITBs as seen on kbird's 335whp N52 build. We have yet to see the true potential of the ESS supercharger as it supposedly made over 20 additional whp (on top of the VT1+) in development and that was without E85 or any further tuning. I'd love to see what a 3.2l stroker would make supercharged! Nothing like negating the proven reliability advantage of a silky smooth engine What do you think? Sorry for the BS post. |
04-13-2015, 09:29 PM | #2 | |
Rep 3,778
Drives: '11 328i '19 M6
Injector upgrade won't be needed as the stock parts have way more flow capacity than needed. Fuel pump is plenty is as well and doesn't need to be upgraded in any way. Getting the head flowed and valve seats properly ground, replacing stock valves with one piece stainless race valves, and having the valve train balanced will return a slight increase in redline and more power in conjunction with coated and wrapped headers and a proper race exhaust. But race gas won't return anything until the compression ratio is increased and that's going to require skimming the head and changing to custom pistons. Better beef up the bottom end and while you're at it have it blueprinted and balanced. You will likely need an oil cooler and improved radiator, possibly waterless coolant and a pressurized system. And colder plugs. MAF is fine but the DME parameters for the engine model feedback would need to be optimized, not simple. Stroking the engine would be a waste of time imo given how much the piston skirts would be thrashed about. But all this with a three stage, etc. should get close to 330hp, net crank. To get to 330rwhp and have a streetable car isn't something that seems doable but I've been wrong before.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
04-13-2015, 10:04 PM | #3 |
Rep 1,286
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
04-13-2015, 10:08 PM | #4 |
Rep 3,778
04-13-2015, 11:22 PM | #6 |
Rep 1,286
04-14-2015, 04:36 PM | #9 |
Rep 7,215
remember that the N52 is already pretty weight optimized - rods, crank, pistons, valvetrain - it's all pretty well put together & balanced. improving on it will be extremely costly. I'd be willing to bet a lot of aftermarket stuff won't even be as good as some of the stock parts.
the N52 head is actually similar to the S54 with the finger lifters, the main differences are valvetronic and having hydraulic lifters instead of shims. of course the ports & valves are smaller and the cam is less aggressive. definitely cams could make a big difference. also, if you want more top end power, a shorter intake tract would help a lot. the 3 stage manifold is great and increasing low end torque and drivability, it's not necessarily great at top end power. I'm willing to bet the guy who did that ITB N52 gained most of his power from ditching the stock intake manifold. rather than doing a stroker, taking the existing displacement to a higher RPM would probably be more effective. Which would require cams and headwork. |
04-17-2015, 09:34 PM | #10 | |
Rep 88
It's not that I can't appreciate even a stock 128i motor (let alone one with a 3IM, tune, and headers), but I'm just excited to see the aftermarket potential. People wrote these off due to potential reliability issues when I doubt many have been modified to be as unreliable as a stock N54 with a tune. Good luck with the regrinds. |
04-17-2015, 09:38 PM | #11 | |
Rep 88
04-17-2015, 09:55 PM | #12 | |
Rep 3,778
Agreed that the manifold inhibits top end gains and that an ITB setup would be better but I'm not expecting to push redline all that much past 7K. Been told 330hp is readily doable though. Going to have to a widebody conversion at some point I guess. Seems more rational than building a stroker or going FI.
04-17-2015, 09:58 PM | #13 | |
Rep 3,778
04-17-2015, 10:25 PM | #15 |
Rep 3,778
Can't get high enough compression ratio with just skimming the head before valve clearance problems appear. No way out without custom pistons to get to 11.5:1 as far as I know. And from what I understand, which ain't much honestly, the valves are technically two piece so it'd be a good idea to go to one piece stainless race valves but no idea if they need to be hollow stem or sodium filled.
04-20-2015, 12:21 PM | #16 |
Rep 7,215
how high would you want to rev though? the stock valves will probably work fine assuming you keep the stock bottom end. the earlier valves have the smaller stems and will be lighter. I presume they went with the larger stems on later motors because the valve guides wear a bit faster.
good point about the CR, but bumping it up to 11.5:1 won't make much difference in power anyway. the dynamic compression ratio may not be as important on the N52 either since even with more aggressive cams, the intake lift and overlap are controlled by the DME. the traditional reason to bump the CR (aside from the small power increase) is because you're using a more aggressive cams and you need the bump since the dynamic CR will drop. since only regrinds are possible at this point, there's not much of a change there either. my main worry for a 10% increase in rev limit would be the bearings. it just depends on how stiff that block is. you could probably do a balance and blueprint on the bottom end and that would likely be enough. |
04-20-2015, 01:09 PM | #17 | |
Rep 3,778
And, yeah, we've been talking about the bearings and the stiffness of the block as well. Seems to be ok for the N54 if the bedplate is pinned. Blueprinting and balancing the bottom end is one of the key items for sure, the question was raised as to whether we should look at other changes once the block is out and torn down but the law of diminishing returns really kicks in hard if it still has to be streetable. Otherwise CR would be higher at the expense of not being able to run on street gas. That and the DME would go as would Valvetronic.
