3.91 Diff swap in my auto pre-lci 328i
04-19-2015, 04:11 PM | #1 |
Rep 16
I am interested in doing a diff swap into my auto 328i. I know mine has the 3.73. Is it possible to swap the 3.91 from an auto 328xi into my car? I found one at an autowrecker for a good price. Will it bolt right on? Will everything work? What do I need to look out for?
Thanks, Bryan |
04-19-2015, 08:54 PM | #2 |
MrSixSpeed
40
Rep 920
It should work. On e46's, you usually swap your existing "yolks" or output flanges to the new diff. You may need to do the same on e9x's.
Unfortunately you will only see a nominal performance increase as you will be multiplying your torque output by a very small %. I don't believe the juice is worth the squeeze. |
04-20-2015, 11:37 AM | #4 |
Rep 16
04-20-2015, 04:41 PM | #6 |
Rep 198
04-20-2015, 05:07 PM | #7 |
Rep 525
Not sure this is a good idea in an automatic, yes acceleration will be better in each gear, but you're transmission will need to shift more often which I'm not sure you want considering how "fast " our transmissions shift
04-25-2015, 09:19 PM | #8 | |
Rep 4,040
Drives: 130i coupé ;)
I thought this was not possible because XI have different half shaft mounts into a larger bearings and larger knuckle with the large hand brake shoes. While the 328i has small hand brake and smaller bearing and as such the hald shafts wont fit the XI diff halfs. Did you swap half shaft flanges?
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is Last edited by andrey_gta; 04-25-2015 at 09:29 PM.. |
04-26-2015, 01:08 AM | #9 | |
Rep 198
04-26-2015, 01:13 AM | #10 |
Rep 184
Few thoughts, if I may...
3.91/3.73 = 1.048, so the gain would be mere 5%, something you will (probably) not notice at all, where you used to rev 3000, you will be reving 3150 I just did a swap 4.28 -> 5.00 on my other car (Z4 e89 3.0i) ie something like 17% gain (instead of 3k revs I am at 3.5k now) and I am thrilled - whatever gear I shift in, it runs like hell, even against a steep hill climb... to be honest I gotta say the mileage dropped by approx same ratio (with the "summer driver" I don´t care a bit about) Probably I will go the same way even with my daily (e91 330ix MY2011 EU specs, both diffs to be cut by exactly same ratio of 15%) and will have to live with the decreased mileage cos the fun factor gain is just (in my eyes ) worth it.
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear) |
04-26-2015, 09:28 AM | #11 | |
Rep 4,040
I am asking because i dont want to go to 3.23 to 3.73 and something like 3.46 or 3.38 would be ideal. The problem is that i think someone like BudVlad had to have a drive shaft cut and modified to use the 3.38 diffeential's flange
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
04-26-2015, 12:53 PM | #12 | |
Rep 198
I didn't want to go to 3.73 either, and found this low mileage 3.38 for cheap. Was doing the LSD also so was a good time. |
04-26-2015, 02:00 PM | #13 | |
Rep 4,040
Also for the above 8% gain up to 12% is what is typically recommended for differential swaps based on some article of a z4 supercharged 3.0 that I read. This is why I wish to avoid a 15% gain if possible. FYI I think e60 pre lci prior to 2005 with the m54 engines had the same pumpkins, they may need also need shaft flange swap, but they do offer good ratios.
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is Last edited by andrey_gta; 04-26-2015 at 02:08 PM.. |
