F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Still no harness solution for the F30?
proTUNING Freaks
      04-23-2015, 10:10 PM   #1
ATLBlue
Car OCD
ATLBlue's Avatar
Drives: 2017 EBII F36 430d M Sport
I am planning on occasionally taking my F30 to the track. It is not my main track car but would have fun stretching its legs once in a while. Therefore, and because it is my daily driver, I am not considering anything like a rollbar, bucket seats and 6 point harnesses.
Knowing the pro's and con's, I would happily go for a 4 point removable harness like the Schroth QuickFit Pro so that I could even use my HANS device. There does not seem to be anything available for the F3X yet. I think that in the past, E9X drivers were successfully using Mini R55 QuickFits. Is there anything similar we could do for the F3X? (I am aware of Schroth's warning that you will suffer a broken neck and decapitation when you do so).
I am running out of ideas:
I have already tried the CG-lock... that disintegrated, was uncomfortable and only holds the waist in place. I also tried the seatbelt inertial lock trick... but could not get it to work (not a good fit for me).
I do not trust the cheap GForce $25 AutoX Torso Harness (or should I? Maybe it just ruptures in case of an accident instead of crushing your chest?).
I searched the forums and could not find alternative options
Thanks for any suggestion you may have
2017 BMW F36 430D M Sport Estoril Blue, 2002 E46 M3 Imola Red & 2006 Porsche Cayman S Artic Silver
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL
      05-20-2015, 04:22 PM   #2
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
I'm interested as well if anyone has any ideas...
      06-07-2015, 04:34 AM   #3
M3 Number 86
Drives: black m3
You said you tried the belt lock trick. Did you do it properly?
      06-14-2015, 09:17 PM   #4
ATLBlue
Car OCD
ATLBlue's Avatar
Yes that is how I did it, but I find it difficult to be consistent. Sometimes, the belt is too tight, sometimes, you think it is tight enough and it becomes lose during the session.
Last time I was at the track, I used a combination of this trick and the CG-lock.
I took the opportunity to do a quick fitment test of a Schroth QuickFit Pro from an E92 and it seems to be OK for the F30. I know that Schroth is not going to make the product 'legal' for the F30 until they crashed enough of them, but the size, angles and position of the harness look the same.
I'll give it a try soon.
      06-25-2016, 06:36 PM   #5
DVC
DVC's Avatar
Drives: 335i
Do you have any feedback on the E92 kit in the F30?
      06-02-2017, 03:08 PM   #6
NinTenTom
lurker
NinTenTom's Avatar
Drives: AW F30 Diesel
      06-18-2018, 11:04 AM   #7
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Bump... any harness options that work for our cars?
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      08-19-2018, 12:03 AM   #8
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
https://f30.bimmerpost.com/forums/sh...8#post23611788
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
f30post
