07-10-2015, 05:29 AM | #1 |
Rep 75
left xenon - AHL/DRL/shutter failed?
I drive 428i from 2014 with bi-xenon and adaptive lights (lighting package). After I changed the left xenon plug (the cover fixer was broken) I get the following issues on the LEFT side (right xenon is still fully functioning):
Works: - Xenon low beam - Blinker - Fog + cornering lights Does not work: - Xenon high beam - DLR/AHL (rings) off - Adaptive headlights (+ dash error) - No up/down light check-up at start-up Everything worked ok before the plug swap. I rechecked the wiring (via pictures, numbers), cleaned the connections, re-seated the fuses, even put the old plug back – the symptoms/dash errors are the same. Current issues? AHL module? stepper motors? short circuit? The car is US import to Europe hence I do not have a warranty anymore… :-( Thanks for you help S
bmw 428i (us->eu)
