N52 Motor Mounts, which ones?
07-13-2015, 10:47 PM | #1 |
Rep 1,052
I want to get new motor mounts as mine are looking suspect.
I have a neighbor who can help me with the DIY (he's a pro) but I was wondering what a decent upgrade is for the motor mounts on my 328i. Don't want to break the bank, but want something a little better than whatever OEM is for this car.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
07-13-2015, 10:56 PM | #2 | |
Rep 9,004
07-13-2015, 11:04 PM | #3 |
Rep 1,052
Thought I had read that someplace along the way.
Now to find them. These? http://www.ecstuning.com/BMW-E93-335...unt/ES2695396/
07-13-2015, 11:37 PM | #4 | |
Rep 9,004
07-14-2015, 08:01 AM | #5 |
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
Only the right mount is upgraded for the "is" mount. The left mount is just OEM. I can't confirm if BMW uses different mounts between the 330i and 328i, but when I was looking to upgrade I used the following part numbers:
Left Mount = pt# 22116760330 Right "is" Mount = pt# 22116793240 |
07-14-2015, 09:26 AM | #7 |
Rep 1,052
Do you have a specific suggestion?
07-14-2015, 09:32 AM | #8 |
Rep 9,004
07-14-2015, 10:21 AM | #9 |
Rep 7,215
poly will deform eventually, but technically it lasts longer than rubber.
but really, the stock mounts last for 100,000 miles. get the 335is mounts and call it a day. extra NVH isn't worth it unless you're building a pure track car. |
07-14-2015, 11:46 AM | #10 |
Rep 3,778
Drives: '11 328i '19 M6
I'll second that.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
07-14-2015, 02:22 PM | #12 |
Resident Tamed Racing Driver
298
Rep 4,697
Depends on the brand. Certainly seen a number of Powerflex failures over the years. For engine mounts I definitely would opt for sport focused factory rubber over aftermarket options.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
07-14-2015, 04:11 PM | #13 |
Rep 3,778
FWIW there are no Group N engine mounts for the N52
07-14-2015, 05:29 PM | #14 |
Rep 9,004
07-14-2015, 05:43 PM | #15 |
Rep 3,778
AKG mounts were the only ones I could find but then I needed the closest thing to solid mounts I could get to make the shifter usable on the track.
07-14-2015, 05:47 PM | #16 | |
Rep 9,004
07-14-2015, 05:50 PM | #17 | |
Rep 3,778
07-14-2015, 07:14 PM | #18 |
Rep 1,052
Well i'm sold on the 335is part 22116793240 as long as they really fit the N52 e90, and it sounds like that's what you guys are saying.
http://www.ecstuning.com/BMW-E92-335....0L/ES1897640/
07-14-2015, 07:20 PM | #19 | |
Rep 3,778
07-14-2015, 08:33 PM | #20 |
298
Rep 4,697
Definitely the issue when replacing worn out mounts. Pretty much anything will feel like an upgrade.
07-14-2015, 08:52 PM | #21 |
Rep 3,778
Definitely agree, good point.
07-15-2015, 08:01 AM | #22 |
Custom User Title
412
Rep 1,337
What solution did you end up going with???
