08-04-2015, 11:03 AM | #1 |
Rep 2,964
How to remove side vents (boomerangs) etc...can anyone help?
Searched high and low for a "how to" on this but haven't come up with anything - looking for how to remove the side vents on my F36 / seems simple enough and it looks like there are a couple clips holding them in so Im sure I can figure it out but if anyone can offer some tips I would appreciate it
08-04-2015, 04:04 PM | #2 |
Gettin It Figured Out
1823
Rep 2,669
Pretty straight forward. Use a plastic pry tool, VERY high probability you'll snap plastic nipple/clip holding them to fender as they are incredibly fragile.
08-04-2015, 04:22 PM | #3 |
Rep 2,964
08-04-2015, 04:36 PM | #5 |
Rep 519
08-04-2015, 06:28 PM | #7 |
Rep 683
08-05-2015, 07:18 AM | #8 | |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-05-2015, 03:40 PM | #9 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Yeah..I want to remove mine and place an "///M" badge there on both sides....
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
1QuikWS61621.50 |
08-08-2015, 09:34 AM | #10 |
Rep 48
I used a cheap set of trim pullers from Harbor Freight:
http://www.harborfreight.com/5-piece...set-67021.html to do this. I removed mine to vinyl wrap them to a color that better suited my car's color than the default black color: Before (black) & After (anthracite): |
08-11-2017, 07:54 AM | #11 | |
Rep 5
09-06-2017, 01:54 PM | #12 |
Rep 48
09-02-2018, 07:28 PM | #13 |
Rep 1
how to remove and replace side vent / air duct covers, F33
I just removed and replaced the side vent / air duct covers on my F33 BMW 430i 2018 convertible. I used a screw driver to pry them off but was careful to not let the screw driver come in contact with the side of the car (to avoid scratching the car). I used a sudden motion with the screw driver placed against the tip of the at the cover to pop it off. Three motions were required to pop all 3 fasteners. They are located near the two tips and in the center. Using these sudden motions I actually popped it off without destroying the pins. Then I noted that the plastic shells that the pins fit into were still in the side of the car, and the new cover I had also had shells on its pins. I tried to remove one of the shells from a pin on the new cover and broke it; so, don't do that. To remove the shells from the side of the car, I got a pair of needle nose pliers and was able to grab and remove the shells from the holes in the side of the car, again using quick motions. Interestingly, these covers are completely ornamental on my car; there is no actual vent. Then I placed my new cover against the side of the car, aligning its pins/shells with the holes in the side of the car. I covered it with an oven mitt, and struck the end, middle, and other end with a closed fist in 3 quick blows. Each blow popped in a pin/shell and the new cover was successfully installed. Easy peasy... after you have done it at least once and know what to expect.
09-02-2018, 09:42 PM | #14 | |
Rep 118
