Will it bolt? N52 Head on n54 Short block
08-06-2015, 12:32 AM | #1 |
MrSixSpeed
40
Rep 920
Can anyone confirm if the N54 short block is the same casting as the N52 short block. If so, will a n52 head bolt up to a n54 block?
Bore and stroke are identical. The material spec is different. N54 is aluminum with iron sleeves. N52 is Magnesium with aluminum sleeves. From the pictures I have gathered they appear identical. Anyone have first hand knowledge? TIA
Recent polling data indicates that 100% of manual transmission drivers can operate a vehicle equipped with an automatic transmission.
08-06-2015, 09:00 AM | #3 |
Rep 2,239
I've always wondered if it was possible to take the n54 block, mate it to an n52 head, throw on the ESS supercharger and crank the boost and see what happens.. now that'd be a fun car.
08 e93 335i MT
08-06-2015, 09:25 AM | #4 | |
MrSixSpeed
40
Rep 920
Again this is all on the assumption that it would fit. Anyone? |
08-06-2015, 10:31 AM | #5 |
Rep 7,215
pick up an N52 and an N54 head gasket and see if the holes line up.
N52 valves are larger than N54s as well so there could be piston/valve interference issues. |
08-06-2015, 10:36 AM | #6 |
MrSixSpeed
40
Rep 920
Great suggestion and info.
08-06-2015, 11:19 AM | #7 |
Rep 7,215
If you are lucky you can find a used one instead of having to buy a new one!
are the bore sizes the same? I'd think so. that would help with the shapes of the combustion chambers & pistons. |
08-06-2015, 12:31 PM | #9 |
Rep 7,215
why not?
insomniscient0.00 |
08-06-2015, 12:37 PM | #10 |
Rep 234
Lots of labor for a strong bottom end, with no improved power, heavier weight, and still stuck at 300HP until better injectors come along...
I hate to be that guy, but I'd just buy the 335... |
08-06-2015, 01:37 PM | #11 |
Rep 7,215
the idea does have some merit beyond 335i vs N52. The N52 head should flow better than the N54 (better ports, bigger valves, cams, etc). BMW couldn't fit both valvetronic & direct injection on the N54 (until the N55), but that doesn't mean it couldn't work with a turbo or a supercharger, obviously.
but, whatever. half you guys are afraid to change an air filter, so I can see how something like building a modified motor would scare you off.. |
08-06-2015, 02:49 PM | #13 | |
Rep 234
You could lock-open the valvetronic and go with port-injection, but I guess I'm still missing the point... What's the goal here? So you want the most volumetrically efficient, forced induction motor? Sounds great, in theory i guess. In reality, just up the boost and you get the same effect. Want to get rid of *all* turbo lag? Put a supercharger on an N54 engine... I guess I just don't "Get it"... |
08-06-2015, 05:11 PM | #14 |
Rep 7,215
upping the boost does NOT have the same effect as increasing VE. Upping boost pressure increases lag and heat; the power increase isn't linear. Increasing VE automatically increases HP (at the same boost pressure) without those drawbacks.
it's just a discussion. I mean, if you don't have something constructive to add, then why even post? |
08-06-2015, 05:12 PM | #15 |
Rep 7,215
08-06-2015, 06:12 PM | #16 |
Rep 1,192
There are better injectors, but we should try to boost the fuel pressure first.
08-06-2015, 06:34 PM | #17 |
Rep 1,402
Just add a second set of port injectors.
I have a used N52 head if someone has a N54 or N55 block. Any advantage to either the N54 or N55 blocks? |
08-06-2015, 07:05 PM | #18 | |
Rep 234
Trust me, I love my car and its motor. I also think doing a hybrid engine like this is just silly, because you're limited by the fuel injection no matter which short-block you put under the head. If someone figures out how to fuel an N52 enough to boost it to the point where it grenades, then yeah, its time for a new bottom end. But honestly, we don't even know how near/far we are from that point... Constructive advice? Save your cash until we can fuel the engine... Right?? |
08-06-2015, 07:17 PM | #19 | |
MrSixSpeed
40
Rep 920
Good to know. Bottom line is boost solutions will emerge for the n52 platform. Each new solve will be met with a new limiting factor. I am confident fuel delivery will be solved and when it is, block integrity will become a concern along with aluminum bolts. If I remember correctly, this was BMWs talking point for why they chose not boost the magnesium block.
08-07-2015, 11:36 AM | #21 | |
just another bmw douche bag
195
Rep 3,640
