09-26-2015, 05:56 AM | #3 |
Rep 143
This doesn't sound like a "M" engine like we know them from the past. It reaches the 360 PS at 5800 - 6000 U/min. That max output at 5800 - 6000 U/min is very low for a "real" M engine. The M4 reaches its max output between 5500 - 7300 U/min. Furthermore you can read "M Performance Twin Power Turbo" and not "M Twin Power Turbo". The M2 won't be a "M Performance" 2 Series like the M235i, so this wouldn't match.
And I talked with my source this morning and he said that he do not think that this will be the M2 engine. |
09-26-2015, 06:07 AM | #4 |
Rep 2,643
^^ Agree.
The '40i N55 engine is too limited at the top end RPM. At least the 35i attains max power up to 6400rpm. The M2 version needs to beat this and hold more power to the redline to make it a satisfying drive as a M car. |
09-26-2015, 07:33 AM | #6 | |
Rep 12,313
09-26-2015, 09:09 AM | #7 |
Rep 143
No, I didn't forget that but you shouldn't compare the 1M with the M2 in this case I think. The 1M was the first M with a Turbo engine. Now BMW has much more experience building high revving turbo engines duo to the S55. The M235i gets his peak (PS) at 5800 - 6000 U/min and I would expect that the M2 should be able to get its peak a little bit higher. That is what I expect for a M engine compared to a "M performance" engine.
09-26-2015, 12:12 PM | #9 | |
Rep 8,185
1 M/35is' peak power was at 5,900 RPM, btw. N54 was already three four years old so in my opinion they were not exactly new to the game. My point is, though, that there might be analogy between the Z4/1M and X4/M2 again. Same engine but maybe with slight SW changes (or HW - who knows).
09-26-2015, 01:21 PM | #10 |
Rep 2,897
Very sad to see these M performance engines thrown under the hood of M cars.
It was sad with the 1M, but excusable due to the lack of development time, however this time around it's just pathetic and inexcusable. |
09-26-2015, 02:42 PM | #12 | |
Rep 2,008
Much about BMW has changed in the last 10yrs. And not for the better.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe (Past): 2016 F30 340xi M-Sport -2013 535i xdrive 2008 E92 M3 - 2006 E90 325i 2002 E46 325xi - 1991 E30 325i |
09-26-2015, 02:44 PM | #13 |
Rep 1,270
This doesn't bother me at all. Presumably, the M division is going to take the N55 and modify it to meet their standards. The N55 is a great engine and will that much better once the M folk get done with it.
09-26-2015, 04:12 PM | #14 |
Rep 846
Unfortunately it doesn't work like that. Case in point: 1M.
09-26-2015, 05:07 PM | #16 |
Rep 2,820
Think he's saying that the 1M had the identical engine from the Z4 35is so the M2 could very likely get the identical engine from the 40i cars..
09-26-2015, 05:36 PM | #18 | ||
Moderator
29682
Rep 13,139
In October 2014 forum fellow ynguldyn already indicated that the X4 M40i and M2 both will feature the N55B30T0 engine.
///M is art ↔ Artemis
09-26-2015, 06:29 PM | #20 |
Rep 3,444
It's really the same story over and over again. M3 with a turbo - outrage! M versions of X5 and X6 - outrage! 10 cylinder M5 - outrage! 8 cylinders in M5 again, but with a turbo - outrage! When BMW announces an xdrive M car, it will be - you guessed it - outrage! all over again. And so on, ad infinitum.
BTW that 1M with the "excusable" engine is a collectible now. |
09-26-2015, 06:44 PM | #21 | |
Rep 2,897
I wouldn't mind a detuned S55 with the same 370 hp, I want an engine that has character, builds revs fast and doesn't run out of steam in the higher RPM ranges, also it needs to rev to at least 7500 rpm. I can't justify an N55 M2 because a) I already have an M235 and b) the M3 exists and to me seems like a better value than an N55 M2 |
09-26-2015, 06:46 PM | #22 | |
Rep 2,897
The M2 with the N55 engine and higher production volume is not going to be a collectible. The 1M is because it was so rare. |
