First oil change with new jack stands.
10-25-2015, 11:06 AM | #2 |
Major Private First Class
450
Rep 1,327
Drives: 2010 E90 335i M Sport
How did you modify it? I think I have the same jack stands, I don't see a difference.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
10-25-2015, 02:03 PM | #3 |
Rep 474
10-26-2015, 04:51 AM | #5 |
Rep 18,801
Use a lift and the jack pads (BMW calls them lift points) and they make perfect engineering sense. Most people here use an axle stand, which is not the right tool. Get the correct stands and no modification os necessary. Kinda like taking a 10MM wrench and grinding the flats down to make it a 12MM...
10-26-2015, 07:58 AM | #6 | |
Rep 14,829
10-26-2015, 10:52 AM | #7 |
450
Rep 1,327
LOL...thanks for the laugh. BMW left a freakin broken valve cover/head bolt after snapping it.
10-26-2015, 11:30 AM | #9 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
10-26-2015, 03:42 PM | #10 | |
Rep 30
10-28-2015, 12:44 PM | #11 |
Rep 9
10-28-2015, 11:20 PM | #12 |
Rep 369
10-29-2015, 07:29 AM | #13 | |
Rep 311
Got the idea from this thread. http://www.1addicts.com/forums/showthread.php?t=685917 |
10-29-2015, 08:45 AM | #15 |
Rep 9
10-29-2015, 10:08 AM | #16 |
Rep 475
Drives: Yes
10-29-2015, 12:04 PM | #17 |
Rep 369
10-29-2015, 12:05 PM | #18 |
Rep 6,196
10-29-2015, 04:06 PM | #19 |
Rep 18,801
I have a lift. When lifted, the car sits canted rearwards a slight bit; it's not perfectly level. I use an under-hoist stand at the diff (think giant 3-point jackstand with an ACME screw thread on top) to level the car, and more oil drains out of the pan.
10-29-2015, 04:13 PM | #20 | |
Rep 30
I'd think the clearance problem would even be bigger with 17s or 18s. |
10-30-2015, 02:21 AM | #21 | |
Rep 369
01-07-2016, 04:29 PM | #22 |
Rep 3,556
I have an engineered solution for those of us that can't install a lift in our garages. See pics please. The nice thing is the rectangular block is on top of a spherical joint. This is so that the block can rotate while opposite end of car is being raised or lowered. Shop Reverse Logic to get these stands and special inserts. I have no affiliation with these company other than buying the 4 stands and posts. Fred is a great guy to work with.
