E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > One last go at Santa Pod
Reply
      10-25-2015, 06:04 PM   #1
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
Hi guys,
well I've been to Santa Pod about 10 times this year now. I only planned to go once but each time I kept thinking I could do better and I had to go back to try.
My first attempts at the start of the year showed me I didn't know how the heck to launch the car and saw me getting 14 seconds. Later I managed to figure a way to move off by holding the car on the brake and engaging the accelerator just a bit to engage the clutch of the DCT. Brake boosting isn't possible.
I managed to trap over 110 mph before adding meth injection and then managed just under 12.5 seconds ET with the meth at 117 mph. Later I started using a back end flash to better use meth injection and ethanol added to my fuel but I always found that the flash never quite worked with the DCT transmission. The shifts felt off and laggy. The car really lurched. It was like changing gear in a manual and not quite fully getting off the clutch. So for this reason I got a custom flash done by Trebila. Some people use Wedge or Spxx or other. Anyway in the recent tests at home the shifts felt really good and the car felt fast so I had to hit the strip again.
I went running 25% ethanol in the fuel tank and meth+water at 60:40 to suppress some timing pulls I was getting on cylinder 2. I've tried changing the spark plug and coil pack but I can't get rid of this issue. It's probably carbon build up in the cylinder, a bad injector or false knock. Anyway timing was pretty food on my runs with just cylinder 2 a little behind.
Running a 50 meth adder I managed to break my previous best trap speed of 117.95mph with 118.06mph but my time was a poor 12.9 secs due to a near 2.5 sec 60ft time
I was happy that the car had potential. However my second run was 13 seconds and 117mph. The next 4 of 5 runs also saw 2.4 sec 60ft times killing my ETs.
Then on my last run of the day I nailed a good 60ft time of 2.1410 secs. I had the car on the absolute limit of grip without spinning too much and cruised to a 12.2179sec@120.59 mph. That's M4 trap speed right there. I'm sure if I had better tyres I could break into 11's.
Anyway very chuffed and probably going to leave Santa Pod until next year now. But you never know
Video, time slip, log to follow...
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      10-25-2015, 06:37 PM   #2
AWSAWS
AWSAWS's Avatar
283
Vid when uploaded:
Time slip:
      10-26-2015, 04:04 AM   #3
jamesmurray
United Kingdom
12
Drives: E92 335i
That's a great time! I'm planning on going this Sunday for the last rwyb of the year. I've not run the 335i before so it'll be interesting
James
2009 E92 335i Titanium Silver
JB4 G5, BMS/MHD Race flash, Pure Stage 2 DD, RB Turbo inlets & outets, BMS Meth kit (60/40), Wagner Downpipes & Intercooler, CPE Charge Pipe, Ramair DCI, DCT Paddles, Alpina F30 big brake kit, ST/KW variant 1 coilovers, M3 ARB and control arms
      10-26-2015, 05:09 AM   #4
AWSAWS
AWSAWS's Avatar
283
James
As everyone who has been will tell you. It's all about the launch and the 1st 60 ft. Good luck!
p.s. I always felt my car had more than the 117 it was achieving. Firstly because of the aweful traction off the line and secondly because my DCT was never working quite right. The service I had a few months ago also helped. My brother beat me to the line twice in those videos but my ETs are lower each time.
      10-26-2015, 05:24 AM   #5
russjonesr
Drives: BMW E92 335i
Hey Jack,
Trebila definitely has the car dialled into perform with your DCT gearbox, well worth the investment! Consistently over 120 that's getting serious
Like you say, stick some drag radials on and you will be in the 11’s !
Well Done bud
I will have to practice brake boost for next time!
Jb4 with Trebila BEF,vargas stage 2+ turbos, vrsf dp's, vrsf cp with tial bov, vrfs 7" fmic, EOS PI with BMS PI controller, RB Inlets and Outlets, bms meth kit, BMS DCI, miltek cat back, bms occ,3.5 tmap, ngk 5992 plugs, HSD coilovers, M3 rear subframe, diff, drive shafts , suspension and brakes.
      10-26-2015, 05:28 AM   #6
AWSAWS
AWSAWS's Avatar
283
Originally Posted by russjonesr View Post
Hey Jack,
Well Done bud
Yes mate,
the guys in the states get some seriously good times off the line with the brake boosting in 2nd on steptronic.
There's an enourmous bonfire there soon. You should take the kids
      10-26-2015, 05:45 AM   #7
russjonesr
Just looking at the log! You're pushing that LPFP I see you are short shifting and not a full throttle in 1st and 2nd too much wheel spin? Love to see what you could do with some VP109 and some 275 nitto nt05r on the rear!
Or is it time to invest in a stage 1 pump???? Might be a visit to Shrewsbury again
      10-26-2015, 06:01 AM   #8
russjonesr
Originally Posted by AWSAWS View Post
Yes mate,
Yes, I saw that...unfortunately we have other plans...it may have been a different story if the inlets would have arrived and David had worked his magic
      10-26-2015, 07:04 AM   #9
AndyN
United Kingdom
16
Drives: E92 335i & E93 335i DCT
2010 E93 335i DCT  [0.00]
2006 E92 335i  [0.00]
I think you're getting into territory where you desperately need a LSD!
It'll transform your launch and first 60ft.
E93 335i DCT M-Sport
Turbo Dynamics Stage 2+ Hybrid turbos - Evolve FMIC - VRSF catless DPs - Remus Race exhaust - Injen CAI - VRSF CP & HKS BOV - Quaife LSD - Gladen 120.4 DSP kit - CIC to NBT Upgrade - JB4 G5 w/ race flash - Ohlins R&T suspension -
next mod: go faster stripe.
      10-26-2015, 07:30 AM   #10
AWSAWS
AWSAWS's Avatar
283
TBH I don't think I'd bother with a LSD. Better tyres would be a more economical way to go. I think I'll get some Toyo R888 next year.
I had to really modulate the throttle in 1st and 2nd. That's how the low 60ft time was achieved. Before each run I did a small wheel spin to heat the tyres. In 1st gear I can just go full throttle and the wheels spin immediately, the car barely moving. I didn't hold it against the brake as I don't want to wear them any faster.
On the lpfp I think maybe the flash just isn't quite able to handle rapid changes in demand for fueling, with ethanol and meth and water injecttion and rapidly varying trims. I may play with the fuel scalar a bit.(See the trims are 30's and 20's in 1st and 2nd, but 0 in 4th and 5th!) I also don't know if standard pumps cope well with low levels. Do they have the venturi to help maintain flow when acceleration may throw the fuel to the back? Anyway an upgrade will happen at some time.
For me this puts the run into perspective
      10-26-2015, 07:54 AM   #11
The0pportunist
The0pportunist's Avatar
United Kingdom
481
Drives: F30 335i
Scooby: Dude, i almost had you.
      10-26-2015, 07:59 AM   #12
AWSAWS
AWSAWS's Avatar
283
haha yeah
He was a nice chap. I had a chat with him. His back window was full of cuddly toys so I wouldn't say he's too hard core.
      10-27-2015, 06:11 AM   #13
AirAndre335i
AirAndre335i's Avatar
39
Drives: E92 335i Pre Lci
Definitely no LSD is needed. Good times but you can definitely do better.
As you say, work on that 60ft and get your self some better tyres. No LSD was required recently for an N54 to break into the 10s... so Tyres it is.
You should definitely not be wasting any time launching in 1st. Why not just limit boost in second so you can push it to redline? Or use the JB4 to limit it in lower rpms and maintain a higher boost in higher rpms in second gear?
      10-27-2015, 06:20 AM   #14
AWSAWS
AWSAWS's Avatar
283
I don't launch in 2nd because I have the dual clutch transmission. The gear ratios are actually all different as well due to the 7 gears. The way I got that 2.1 sec 60ft time (I think ) was to reduce the 1st gear boost limit to under stock (7psi vs 8psi) and to be really careful in 2nd.
      10-27-2015, 06:33 AM   #15
AirAndre335i
39
LOL awesome.
DCT is unknown stuff to me.Lower than stock is crazy haha. The Xdrive e92s in the states launch like crazy
      10-27-2015, 08:24 AM   #16
AWSAWS
AWSAWS's Avatar
283
LOL awesome.
Well mate even on 7 psi at santa pod, if I just put the pedal to the floor the cars wheels just spin up.
The Xdives are great of the line but the added weight of the 4WD means they suffer on the trap speed.
      10-27-2015, 10:25 AM   #17
RajB
RajB's Avatar
448
Drives: E92 335i
Excellent final run. Nailing the initial 60ft is bloody difficult as you say you have to really be careful with how you apply the power to stop just lighting up the rears.
      10-27-2015, 04:29 PM   #18
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Congrats. 120mph plus is an excellent time. Its very hard to get a good 60ft time.
Making me wanna go back this Sunday, but i'm going Rockingham next week
      10-27-2015, 08:00 PM   #19
AWSAWS
AWSAWS's Avatar
283
Good luck matey! Temps are going down so good for the engine at least. Tame the torque
      10-28-2015, 06:46 AM   #20
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Thanks mate, it's not a full on track day, only a 30 minute taster session. I would love to go on a full track day but it will cost around £400 including insurance too. This will only cost me £30 and fuel
Might go to a full track day in the Spring when the weather is better. Really want to go Bedford.
      10-29-2015, 07:09 AM   #21
AWSAWS
AWSAWS's Avatar
283
Definately get as much insurance as you can. I've seen so many incidents on youtube. I'd hate to be trying to pay for fixing my car should I spin out or worse, get driven into by someone else.
Just think how this guy in the BMW felt!
"I'll just go out and take it easy. What's the worst that could happen, right!?"
Hope he had cover
      10-29-2015, 12:15 PM   #22
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
I'll definitely get insurance for a full track day. But for 30mins on a taster session? Rockingham said they have never had a single incident on a taster.
But when i go to a full day then insurance is definitely something i'll be getting. As like you say, even if i'm driving ok, it could be someone else driving like an idiot.
Reply
e90post
