O2 sensor codes heater fault all four sensors
10-27-2015, 03:56 PM | #1 |
Rep 212
If you get 4 codes for your O2 sensor heater circuit check your crankcase vent heater under the intake manifold. Mine was rotted so bad that when I touched it with a screwdriver the two wires just fell out. Part is about $90. I spent too much time trying to find a wire fault with the O2 sensor wires - if I had checked this first I would have seen the problem.
01-20-2016, 07:33 PM | #2 |
Comfortably Numb
627
Rep 654
Drives: '18 x1/'13 X3/'06 330i
Check Engine Light on, faults for all O2 sensors.
Dealership diagnosed the car and found sensors to be good. Further check found a blown fuse (Fuse #4 underhood engine electronics), replaced it and the fuse immediately blew again. All lines and connections were good and found a short circuit in the Crank Case Heater Valve. Replaced the valve, a gasket along with a clip and fuse, good to go now.
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
