2EF4 Error Code
10-28-2015, 12:28 PM | #1 |
Rep 321
2EF4 Error Code
I was scanning for ghost codes on INPA yesterday and came across a 2EF4 error code. I ran my generic code reader on it too and it came up with a P0128 Coolant Temperature below control range error as well. I am assuming my thermostat is shot? I don't have SES light.
Out of curiosity, I plugged in my OBD2 BT adapter and ran the Torque app off of my tablet on the way to work this morning. I monitored the temperature along the way and it basically sat between 80-86C most of the way. Ambient was around 15C. Drive consists of 5 miles divided highway (55-60 mph), followed by 5 miles of local roads (a lot of stop and go), and finally 5 miles of actual highway (80 mph). I read that the engine is supposed to operate around 95-97C. Does it seem that my thermostat is stuck open and not allowing the car to warm up to the optimal temps? |
10-28-2015, 02:05 PM | #3 |
Rep 2,494
I don't remember what the actual code was when my thermostat failed, but I didn't have a check engine light either. Come to think of it I don't even remember what prompted me to check it :/
10-28-2015, 02:30 PM | #4 |
Foodie and Gearhead
102
Rep 733
Drives: 2011 335i xDrive Sedan
Based on the pic in this thread, looks like the thermostat could be stuck open:
http://www.xoutpost.com/bmw-sav-foru...2ef4-2f09.html My assumption is that it's time to replace it.
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
10-28-2015, 03:19 PM | #5 |
Rep 321
Word. That's what I came the conclusion to as well. Question: I am on the original thermostat and water pump. When I do the thermostat, should I also change the water pump as well even if there are no signs of it failing? The car has 114k on it. I would like to change it, but I am not sure it's a preventive maintenance thing or not considering the price of one is $400.
10-28-2015, 04:43 PM | #7 |
Rep 321
Are there any good DIYs out there on thermostat replacement? I've heard they're a PITA to replace since you cotta go through a sway bar and some PS hoses. It also doesn't help any that's it's tucked in above the water pump.
10-29-2015, 05:05 AM | #9 |
Rep 18,801
2EF4 means the heater core in the t-stat is/has failed. What it means is the engine warmup cycle for low emissions maybe faulty. Normally it throws an OBDII trouble code (SES light). Only fix is to replace the t-stat.
02-28-2021, 11:44 AM | #10 |
Rep 2
Need help figuring out codes
P0030
P2D0D P2EFE P2F04 P2EE0 P2EF4 I was driving home and all the sudden my engine light came on and my car was shaking a lot and reduced power came on. Can anyone help please |
