How long have you had your battery last?
10-28-2015, 02:29 PM | #1 |
Rep 2,808
My car's a 2008 335i E93, and has a black battery in it, which I have read means it is AGM, vs. a lead acid battery that is supposed to be white. I'm surprised, because I wouldn't have expected it to be AGM as I thought most of the older cars had lead acid.
I bought the car back in mid 2008, so it's just over seven years old. It only has 40,000 miles on it though, but it's my DD all year long. When I look up either of the two part numbers, to double check if it is in fact AGM, neither show up strangely enough... AGM should last longer than lead acid from what I had understood, but would 7 years be a good time to replace it anyway? I've had a few odd things happen with the Comfort Access doors not locking as quick as they used to, and reading that you start getting weird electrical gremlins when your battery is dying, I'm wondering if I should just proactively replace it? . |
10-28-2015, 03:27 PM | #5 |
Rep 403
Drives: 2007 BMW 328i
10-28-2015, 03:56 PM | #6 |
No 55mph
1622
Rep 8,477
92Ah AGM in my 09' 328 - lasted 4 yrs
Dealer replaced for free under warranty Everything about the car was fine except I was getting a constant re-occurring '2DEB' Power Management code at time of replacement. Battery was checked & found to be weak
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-28-2015, 09:28 PM | #7 |
Rep 100
My original battery lasted until earlier this year; about 8 years, and 80k miles. It was a white top too, which makes it even more impressive. Yes, you do start to get little gremlins when the battery is about to go kaput; my side mirrors would aim at the ground when in reverse, but would not come back up after, and I would randomly lose (then they would come back a day or so later) my radio presets as well.
10-28-2015, 09:39 PM | #8 |
just another bmw douche bag
195
Rep 3,640
2006.
replaced mine about 3 months ago due to slow cranks. couldn't tell what it was until I took it out of the car and saw the "Pb" marker on it. |
10-29-2015, 06:21 AM | #9 | |
Rep 2,547
my 08 lasted 6.5 years. non-agm, but put in an agm diehard from sears, all electricals flawless now. |
10-29-2015, 12:16 PM | #10 |
Rep 13,122
Can't play the stereo longer than 10 minutes
Can't play the stereo longer than 10 minutes while the
car is sitting with the engine off. Slow cranks that and it takes a long time to start. This usually happens on the first start of the day. New battery starts up almost right away snappily. |
10-29-2015, 12:34 PM | #11 |
Rep 2,084
2007 335i, 89k miles, still on the original battery. But it's on borrowed time. The comfort access sometimes stops working as well as the rear defroster. Now I try to keep it on a tender if I don't drive it for more than a few days and it's been fine.
2013 135is DCT Carbon Black Metallic |
10-29-2015, 01:09 PM | #12 |
Rep 2,808
Hmmm... I am now hoping my comfort access problems will be related to the battery. I have a heckuva time in the past year locking (but not unlocking) using comfort access, and a lot of times, in the car even, I get the "key missing" symbol on the dash. I'm hoping it's not the comfort access module itself that is acting up.
10-29-2015, 04:56 PM | #13 | |
Rep 1,050
10-29-2015, 06:50 PM | #14 |
Rep 2,808
Yeah, First thing I tried. I have tried both keys, and they are the same. I have replaced the battery a couple of times even in my key fob, and it made no difference.
Locking is quite difficult, and takes multiple attempts. It’s the same on both sides of the car. (I haven’t noticed it as much on the trunk). But unlocking is never a problem. And sometimes when I am in the car, and press the Start button, I get the warning on the dash that the key cannot be found. I leave the key in my man-bag, so if I move the bag a bit, and try again, it recognizes the key. Hoping it's not the freakin' CA module... |
10-29-2015, 07:05 PM | #15 |
Rep 5,458
got my car new 11/2007 just replaced battery a few months ago when it wasn't lasting as long on battery when I was programming it one day - so 7.5 years and wasn't totally done yet.
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
10-29-2015, 07:52 PM | #17 |
Comfortably Numb
627
Rep 654
Drives: '18 x1/'13 X3/'06 330i
2006 330i 43,000 miles, 08/06 build date still on original battery
2006 3251 100,000 miles, 07/05 build date battery replaced in 2011 (slow crank) 2007 328xi 116,000 miles, 09/06 build date battery replaced in 2012 (slow crank)
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
10-30-2015, 07:43 AM | #19 |
Rep 7,215
unless you are having problems, I wouldn't replace it.
the battery on our 2006 E91 is original. I'll probably replace it within the next year since the cold cranks aren't great, but it's fine otherwise. I can't recall if my 330i has been replaced or not but I suspect it has. |
10-30-2015, 08:00 AM | #20 | |
Rep 14,829
Makes me look very foolish replacing mine at 5 yrs. just because. Have to admit, dealer told me I didn't need it. That's $280 I can't get back lol |
10-30-2015, 08:01 AM | #21 |
Rep 14,829
exactly, that's what a load test is for. I learned the hard way because I insisted it be replaced at 5 yrs., just because the scary battery icon appeared one day when it was cold and I was listening to tunes in the car (in reality, that was because my car sits weeks in the garage undriven)
10-30-2015, 11:46 AM | #22 |
Rep 1,225
My OEM batt lasted 5 years, 7 months, 21 days!
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
