Stealth Sub Enclosures Fitted (E92)
10-30-2015, 02:52 PM | #1 |
Rep 52
Just thought I would share my experience......Having tried a variety of options ranging from Twin 12" Alpine ported, Twin 12" JL Audio Bass Wedge and a custom built Twin 10" enclosure I decided to tried a pair of stealth enclosures as I wanted my boot space back and securing these heavy boxes was a nightmare. I was a bit wary of the sound that would be produced from an enclosure of this size and pondered for ages as to go for 10" or 12". As I had a pair of 10 & 12" Alpine Type R subs, I spoke to the manufacturer to see if he would make an adaptor/spacer so that I could use either size - He agreed for a small fee and within 10-14 days I had everything delivered. First I tried the 12s which sounded good but did not drop low enough due to the cubic volume so I attached the spacer/adaptors and fitted the 10s which I prefer the sound of. Yes the JL Audio sounded louder and deeper but it took way too much of my boot space and the compromise of sound vs space I am happy with what I have now. Just need to tidy the wiring a bit.
12" Type R's 10" Type R's |
10-31-2015, 07:38 AM | #2 |
Rep 3,312
Very nice.
I've seen and thought about these to house my Orion 10's as the custom box I have (although small'ish) would still have to go right across the boot area so rendering the through load useless unless I knew in advance I needed it. Who did you use in the end for these?
11-01-2015, 04:01 AM | #4 |
Rep 1,562
11-01-2015, 05:30 PM | #5 | |
Rep 52
I used Visual ICE - they are on ebay but contact directly to get a lot better price - http://www.ebay.co.uk/itm/Bmw-E92-3-...8AAOxyUrZS5hDC |
11-01-2015, 05:36 PM | #6 |
Rep 52
Thanks - Just depends what sound you going for really....If its SPL then no...but if you want a nice thump and roll it will more than do that....I am still running OEM speakers with no amplification....Days of setting off car alarms and shaking the place are over....
11-02-2015, 01:35 PM | #8 |
A family of bimmers
2757
Rep 7,743
that looks great. have you thought about running the speaker wire under the carpet though?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
11-02-2015, 03:08 PM | #10 | |
Rep 3,312
11-03-2015, 01:41 PM | #11 |
Rep 52
11-03-2015, 01:43 PM | #12 |
Rep 52
When I installed it was just to test the fit and just have not had the time....and as time has passed and it is not a show car its not that important.....perhaps in the spring time....
11-03-2015, 01:49 PM | #13 |
Rep 52
Feed to amp is tapped into the OEM wiring loom....I did not do myself - got an installer to do it....He offered various options and I have both JL Audio SS1 and CLS441 DSP....but didn't bother to install as I was not going to go all out and amp the OEM speakers.....One thing though is that you need something to increase the voltage from the head unit to the amp (line driver). I had a small Kenwood Graphic EQ which is hidden away which boosts frequencies and voltage...I know its not the perfect option but it serves my needs.....
11-03-2015, 01:54 PM | #14 |
Rep 52
