Talk to me about e85 and 112 octane
10-31-2015, 07:59 PM | #1 |
Rep 191
Hey guys, n55 jb4 map5 (will do the 3WOT Runs) cp, dp, and fmic. I'm looking to race my friend and want to smoke his 5.0. Am I better off with 93 octane plus 3 gallons of 112 or 3 gallons of e85? Is e85 (really like e20) safe to use once a month if I only use 3 gallons for a full tank? What're the negatives because my friends telling me I'll ruin my injectors! Thanks
10-31-2015, 10:24 PM | #2 |
Rep 3,554
Why is your e85 really e20?
And no you won't ruin your injectors. I had been running full e85 for over 10k miles and atleast an e30-40 blend for another 40k miles with no issue |
10-31-2015, 10:44 PM | #3 |
Rep 191
On stock Fuelpump? I'm at 65K and a little worried
I had 10g e90 and 2.8g e85 ran it hard on the highway for an hour and no issues.. Slightly longer startup the next few times I started the engine? I might move up to 4g. I hit 16.5 max I was expecting more |
11-01-2015, 05:29 AM | #7 | |
Rep 350
Just don't let e85 sit in your car unused for more than 2 weeks. Ethanol attracts water. If your really want to smoke him run e50 with Bms backend flash for e85. Oops you'll need a stage ii lpfp upgrade. |
11-01-2015, 12:42 PM | #9 | |
Rep 2,189
The higher the E content the less likely it is to separate. I've left E in my tank and gas cans for 5 months before without any ill effects.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
11-01-2015, 06:29 PM | #10 |
Boost
1355
Rep 3,695
Drives: 135i M-Sport
Seriously people need to stop worrying about running e85... There are people who have been running it in their N54 for >50k miles, myself included (E60)
Throw 4 gallons of E85 in there and make a custom map 6 with 18psi peak targets, and load the race backend flash and you'll "smoke" him. |
11-01-2015, 07:31 PM | #11 |
Rep 3,190
He has an N55 so no race BEF. You can put in 5 gal E85 and the rest 93. Use map 7 and you should beat him just fine. Make sure your FOL is 70-80, and that you log to make sure everything is fine.
11-01-2015, 08:13 PM | #12 | |
Rep 350
besides i take my advice from Steve from fuel it... hes pretty much an ethanol expert. |
11-02-2015, 09:54 AM | #14 |
Rep 191
I dont have flex fuel wires, will i survive. Also, any ideas on what would cause rough idle(at park or at a red light) usually after driving hard? RPM drops to 400 and car shutters, the rises to 1000ish
11-02-2015, 05:09 PM | #16 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
could be running too much e85 for the stock flash and no ff wires, if you are running e.
