Help! Brake caliper guide pins keep turning!
11-03-2015, 01:12 PM | #1 |
Rep 272
I need immediate assistance. I was trying to finish my brake job by inserting the brake caliper sliding bolts. The top one went in fine, no issue. The bottom one on the other head just keeps turning. No matter how much pressure I apply it wont go in. Is there any trick to this? I tried to insert the top pin into the bottom slot and it wont go in. Any help please!!
Afe Stage 2 Magnum Intake - Custom SS Exhaust - AG M359 Staggered - CF spoiler
11-03-2015, 01:21 PM | #2 |
Rep 18,806
Pull the pins from the caliper. Take the caliper off the carrier. Hang the caliper by some wire from the spring so it's out of the way. Then look at the threads on the pins and the treads in the holes to make sure they are not stripped. Then practice installing the pins into the carrier without the caliper in place so you can verify both pins thread in properly. Then go and reinstall the caliper. It's usually just finding the alignement of the pin to the hole. Sometimes you just need to push the caliper from the top towards the hub to get the pin to line up with the threaded hole in the carrier.
11-03-2015, 01:22 PM | #3 | |
Rep 272
11-03-2015, 04:10 PM | #6 |
Rep 272
I didn't get a chance to check tonight since something came up. will have to tackle it in the morning. The thing is when I remove that bolt during the uninstillation process, I has the same issue where it would continue to rotate at a certain point but not extract. I had to use a pair of pliers to pull it out. Maybe it's related. if it's stripped, would I have to buy a new caliper? I really hope I don't have to shell out $350 for a new one. Darn it. Thanks for all the replies. Appreciate points for all.
11-03-2015, 07:16 PM | #7 |
Rep 164
It sounds like it's just getting stuck in the bushing.
If you decide to replace because it's something else is it front or rear? I stupidly sheared off a bleeder screw and replaced my rears with remans from Advance Auto. It took a few tries before the ones they shipped me were acceptable but I'm reasonably satisfied with them. I think they were like $100 each but I was able to use 2 $50 off $100 coupons. From my research the fronts are harder to come by. If you do go that route, get the version that states it comes with a mounting bracket, but prepare yourself to be on the phone with them A LOT when they repeatedly ship you units without. |
11-03-2015, 07:30 PM | #8 |
Rep 1,710
Don't tighten one all the way, alternate the tightening.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
11-03-2015, 08:21 PM | #9 |
Is it the shoes!?
3885
Rep 5,112
Be careful that you do not strip them. I've done so before, but it wasn't that bad. 1 day later I found a caliper carrier for < $100 on a forum and I was back on the road the following weekend.
Take the calipers out and try to screw them in. They're easy to accidentally miss when trying to screw them in from the bushings. If they screw in, you're good. If they don't, you need to rethread it, or just snag a new carrier. |
11-03-2015, 09:19 PM | #10 | |
Rep 272
11-03-2015, 09:22 PM | #11 | |
Rep 272
11-03-2015, 10:13 PM | #12 |
Rep 18,806
Boss... just follow my advice. The caliper is not the problem. The pins screw into the caliper carrier. The caliper floats on the pins; that's the intent of the design. You just need to push the caliper in towards the center of the hub, or pull the caliper out away from the hub to get the pin aligned with the hole. If the threads are not stripped on the pin nor the carrier, it's just an alignment issue. It is very hard to strip the pin or the carrier, both are very hard steel. I've about a total of 100 brakes on cars and motorcycles over the past 40 years I've been wrenching. I've never seen a stripped pin or caliper carrier.
Good luck.
11-03-2015, 11:23 PM | #13 |
Rep 3,912
Drives: 330i, 135i
11-03-2015, 11:34 PM | #14 | |
Rep 272
11-04-2015, 05:44 AM | #15 | |
Rep 272
11-04-2015, 05:51 AM | #16 |
Rep 18,806
You can get the carrier separately. Looks like a monkey got into the brakes before you did. Not sure what E92 you have, but the 328i P/N is 34116769095 and the 335i P/N is 34116773203. You'll shit at the price...
11-04-2015, 06:28 AM | #17 |
Rep 272
The price is crazy!! This is the part number for my E92: 34216768696. It's over $140 on most sites. I thought it would be a cheap fix. The price is over inflated. I paid $85 for a rebuilt caliper from Turner, I'll call them and check if the bracket comes with the caliper. They did not have the details on the site. If so, I will just go that route and send back the core. Thanks for the P/N. It took me a while to find it. Its under rear suspension brake components and not brakes in getbmwparts.com if that helps anyone in the future.
11-04-2015, 07:24 AM | #18 |
Rep 164
I think the Turner will come without the bracket. You can get a reman caliper with the bracket for $78 here. I would then just return the new one as the core if yours looks good, otherwise they recommend replacing calipers in pairs. The bracket fits both sides.
11-04-2015, 07:27 AM | #19 |
Rep 952
Caliper brackets are available from recyclers and they will guarantee it to be a good part or replace it. Try ebay or a local recycler.
bone stock
11-04-2015, 08:12 AM | #20 | |
Rep 272
11-04-2015, 09:13 AM | #22 |
Rep 1,157
