Stuttering/lurching, very poor MPG, fluttering idle, and turbo siren - no error codes
11-03-2015, 02:53 PM | #1 |
ಠ_ಠ
74
Rep 1,539
My '07 335i is having a whole host of problems. Namely:
The car has 80,000 miles on it and I've maintained it well the whole time - oil changes at double frequency, filters changed, walnut blasting done, various repairs done at BMW specialty shops, etc. Really not sure what to do here.
| 335i coupe | Monaco Blue | JB4 G5 ISO | Style 313M | Huper 40% tint | Aero lip | CSL trunk spoiler | M3 sideskirts | Paint-matched grilles | Painted reflectors | GP Thunder II angel eyes | Smoked LED sidemarkers | Self-coded | |
11-03-2015, 03:00 PM | #2 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Have you checked the injectors?
11-04-2015, 12:46 AM | #3 |
Rep 1,028
I was going to suggest it's one of your turbos, but that wouldn't kill your MPG like you're saying...hmmmmm.
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
11-05-2015, 07:12 AM | #6 |
ಠ_ಠ
74
Rep 1,539
I'd thought of that, but you'd think I'd be getting codes or logged misfires if that were the case, right? If they weren't so damn expensive and require coding I'd replace them, but with how hard these damn cars depreciated, I can't justify tossing a few grand into it as a "guess and check" measure.
Shoddy BMW workmanship. First set developed god-awful wastegate rattle and wouldn't hold boost, second set had rattle fresh out of the shop. The car was bone stock back then, too. Yeah, I thought about that too. Looked over all the vacuum lines and connections and they all looked good. I've been running the JB4 with boost target on the gauges and it looks fine. I've also tried resetting all adaptations and disabling the JB4, but neither had any impact.
11-05-2015, 09:52 AM | #7 |
Rep 39
I'm new to BMW and this forum...not familiar at all with BMW yet. It says I have to post and wait an hour before my account is upgraded to full fledged account, so I'm attempting this now. Take my words with a grain of salt, as I'm only just becoming familiar with BMW.
As stated, not familiar with BMW, I have owned and am active with the 3/S community. (Mitsu 3000gt/Dodge Stealth) They're twin turbo. From your symptoms/description, it sounds like waste gates are a problematic part on the 335's. Now, on the 3/S's they've got a boost control solenoid, which is tied into the w/g actuators. Wondering if BMW has something similar, that could be causing issues for you, creating some surging issues, which would also wreak havoc on your turbos as well, also the BOV, perhaps? I read a lot of surging issues when people upgrade turbos and BOV's and have everything setup improperly, creating surging issues...though your symptoms are at idle as well, but BMW has a lot of neat gadgets that are electronically controlled, so I'm not sure if wonky things can be happening at idle because of faulty electronics. Is there a way to possibly bypass any of the boost control system, enabling you to run w/g pressure, to see if the problem is eliminated? (I've noticed different platforms have different nomenclature for parts so just to clarify, w/g=wastegate, BOV=blow off valve/bypass valve/diverter valve) |
11-05-2015, 10:35 AM | #8 |
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Do you have any engine code errors?
11-05-2015, 10:38 AM | #9 |
ಠ_ಠ
74
Rep 1,539
I've done a few code reads through the JB4 - absolutely nothing comes up.
11-05-2015, 12:37 PM | #10 |
Rep 2,017
11-05-2015, 12:52 PM | #11 |
Rep 952
A guess - bad engine temperature sensor. This would account for a lot of the factors with the exception of the noise from the turbos. The ECU may be sending too much fuel because it does not know the engine has warmed up.
bone stock
