Paddleshift wheel wiring
11-10-2015, 03:24 AM | #1 |
Rep 250
Morning all.
Getting very tempted to upgrade to a paddleshift wheel. Ideally I would like a DCT wheel, but can't really justify the extra spend. Ive heard that some people have re-wired the standard wheel so that the push function is inactive and only the pull works like the DCT. I was wondering if it is possible to wire the standard paddleshift wheel so that: Push & pull on the left shifts down Push & pull on the right shifts up Thanks David Last edited by drobbie; 11-10-2015 at 03:24 AM.. Reason: fat fingers |
11-10-2015, 06:18 AM | #2 | |
Rep 480
11-10-2015, 09:12 AM | #3 |
Rep 250
Having had a look at the following image:
I thought it might have been possible by: Both cables (red and Blue) on the left paddle connected to one blank port on the multi-switch connector. Both cables on the right paddle connected to the other blank port on the multi-switch connector. Anyone know if that would work?? #CrossTheStreams |
11-10-2015, 10:14 AM | #4 |
Rep 1,661
It's a while since I've played with mine (!), but that should work with the "ear" type paddle. It will NOT work with the later pull-only paddles from 2010-on.
The early "ear" type just have discrete switches in them, the later type have circuitry integrated into the paddle - the fixing to the wheel is different too, but it can be modified if you get a late wheel. Mike |
