Thinking of AA tune on stock N51 328i
11-11-2015, 09:57 AM | #1 |
Rep 7
I recently purchased an 09' 328i auto with 90k and after the two weeks of ownership I can say that it's been a good (not great) purchase so far. The car came equipped with M sport suspension/premium package which translates into a smooth yet firm ride which I'm a fan of. Also the build quality of the 09' is a huge upgrade from the past BMWs i've owned (e36 318is, 325is, e46 325i).
I recently moved to LA and opted for an auto after having owned manual all of my life and I can say that there has been some hardships. First off, there is noticable lag when it comes to throttle response. Second, the power curve on the N51 motor seems to be non linear which i'm not a fan of. I've been looking for some performance mods and from my research I've narrowed it down to an AA tune given the N51 that comes equipped with my 328i. The question i'd like to ask is whether its worth to go with an AA tune with a stock setup, or should I modify a few things here and there (air intake/charcoal delete etc..) prior to the tune. I do not plan on installing a PE or headers mainly due to costs. Any advice would be appreciated. Thanks, |
11-11-2015, 10:10 AM | #2 | |
Rep 10,120
11-11-2015, 10:18 AM | #4 |
Rep 10,120
11-11-2015, 11:00 AM | #6 |
Rep 10,120
If it is auto then you might want to get the tranny fluid and filter changed (if manual then just fluid).. Also the rear differential fluid.
11-11-2015, 11:20 AM | #7 | |
Rep 611
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
11-11-2015, 11:24 AM | #8 |
Rep 1,286
I did a lot of research on this before doing my first automatic transmission fluid change at 27,000 miles; please use the OEM filter kit and the BMW Dexron VI automatic transmission fluid if you have the GM transmission.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
11-11-2015, 11:39 AM | #9 |
Rep 7
My only gripe in regards to perforamance is from stop and go and throttle response. There is so much pedal travel before the car actually moves that its frustrating. I'm hoping the AA tune will help improve that area.
11-11-2015, 12:03 PM | #10 |
Rep 1,286
It will, ask me how I know.
11-11-2015, 12:17 PM | #11 | |
Rep 3,856
11-11-2015, 12:50 PM | #12 |
Mike: Everyone's Pal
2045
Rep 2,972
Drives: F80 M3
Hey listen to me get the AA tune, it makes you cool.
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
11-11-2015, 01:40 PM | #13 |
Rep 1,286
Ummmm. . . some of us were cool before the AA tune.
