DAB Retrofit
11-29-2015, 10:59 AM | #1 |
Rep 1,272
DAB Retrofit
Right, I have a 61 E92 M3, it has no DAB.
What exactly do I need to fit DAB as it would have came from the factory if I specced it and what is it likely to cost? I'm thinking DAB Antenna, Wiring from antenna to CIC, and CIC with DAB connector? and ofcourse coding. Someone told me SOME CIC units have the DAB connector on later models? but you need to pull it out to check. Thanks.
Monte Carlo Blue M3 Comp |
12-04-2015, 02:38 PM | #3 |
Rep 1,272
Ok thanks, If I go to the bother of getting a DAB CIC, is there anything else I should get while im at it, for instance if I decided to fit reverse camera is there another CIC i'd need? or is that another control unit?
