12-14-2015, 09:47 PM | #1 |
Rep 1,770
High beam replacement bulb
Does anyone know where i could get a replacement bulb for my high beams? I have a 4 series with the standard xenons
Instagram: @dg_g20
12-15-2015, 08:40 AM | #2 |
Fool
1857
Rep 3,542
Standard xenons use only one bulb which is a D1S, if it's only high beam that isn't working then it'll be the shutter not moving in the lamp which will be a warranty repair. In fact, the bulbs are covered by warranty too thinking about it!
12-15-2015, 08:42 AM | #3 |
BimmerPost Supporting Vendor
569
Rep 987
Drives: 2022 X4 M Competition F98 LCI
The F3X is equipped with Bi-Xenon headlamps, therefore it shares the same bulb for Low and High Beam. I believe it uses the D1S bulb which you can grab from many HID vendors. Personally ordered my CBIs from powerbulbs due to exchange rates.
12-15-2015, 10:11 PM | #4 |
Rep 1,770
Thanks a lot guys! For some reason, 1 out if every 3 or 4 times when i start the car, there is a message that pops up that says lighting system malfunction. After that message pops up, both the left and right headlights turn off and on again. Any idea what this could be?
Instagram: @dg_g20
12-17-2015, 06:35 AM | #5 | |
Fool
1857
Rep 3,542
12-17-2015, 11:21 AM | #6 | ||
Rep 1,770
Instagram: @dg_g20
