12-19-2015, 11:56 AM | #1 |
Rep 75
Is this the negative battery cable in the trunk?
Hi guys,
I'm trying to disconnect the ground negative battery in the trunk of my 2015 m235i. The battery is not stationed on the right hand side of the trunk but rather where flat tires are at. Anyways, I tried disconnecting the black cable that my finger's pointing at using a 10mm socket, and it created sparks as I was pulling the cable... To my knowledge, ground isn't supposed to create sparks as it's not "hot", am I getting the correct ground cable? Can anyone please tell me where the ground cable is? |
12-19-2015, 12:09 PM | #2 |
Rep 560
That big negative sign next to the post tells you it's the ground. You are booting up the computer when you close the circuit. I see this in my car too when I pulled the negative to work on it.
12-19-2015, 12:48 PM | #3 | |
Rep 75
So my finger's pointing at the correct negative cable and the spark is normal? Just never had spark happen in previous cars so it scared me a little... |
12-19-2015, 01:04 PM | #4 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
It definitely can spark. It used to always spark on my 67 mustang but I swapped the battery and cables because the connections were corroded a badly. Now nothing. On my F30 I get sparks if I ever remove or install the battery terminal connection too sharply/quickly. Be gentle and smooth you'll lessen the chance of sparks. Also I always wear gloves.
Also you need to remove the connection at the Battery terminal to the the ground to the car, not the ground connection at the frame grounding point. If you do that and then the ground cable still connected to the battery can just fall into contact with any metal in the car and suddenly the battery is reconnected and there's voltage throughout the system again which is dangerous.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
12-19-2015, 02:09 PM | #5 | |
Rep 75
Where is the connection at the battery to the ground of the car? |
12-19-2015, 03:08 PM | #6 | ||
Rep 902
12-19-2015, 03:59 PM | #7 | |
Rep 75
12-19-2015, 05:12 PM | #8 | |
Rep 75
But the terminal clamp still can't be slid upwards and off. It can rotate left and right though. I've tried "opening" up the clamp but it wouldn't budge either. Do you know what seems to be the issue? And how do I tighten the nut now that the bolt is loose too? |
12-19-2015, 05:25 PM | #9 | ||
Rep 902
12-20-2015, 12:47 PM | #10 | |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
Wiggle and pull up. You can stick a flat head screw driver to widen the opening but make sure not to touch the screw driver to anything else on the vehicle or battery. |
12-21-2015, 08:31 AM | #11 |
Rep 851
I had this problem too everybody is right push the bottom up and and then unscrew it. BE CAREFUL don't be like me and fry your DME lol.... just don't tap the battery once you get it off and slide it carefully on and off or your will send voltage and spark stuff. just go slow as hell.
