How do I change the turn signal on the E92?
01-10-2016, 12:27 AM | #1 |
Rep 686
I am in a need of changing my turn signals on my E92 and unlike an E90 and the M3, there is no way of accessing the headlight from under the wheels (at least I didn't see a way). So how do I do it? Do I have to take off the whole headlight to do this, or is there an easier way?
I have searched the internet and all I see is tutorials on how to do this for an E90 and the M3, but the E92 is nowhere to be seen Thanks! |
01-10-2016, 05:11 PM | #2 |
Rep 503
Drives: e92
Definitely easier way, I'm thinking wheel well, did you check drivers manual?
01-10-2016, 05:28 PM | #3 |
Rep 10,033
It's either from the wheel well or I beleive you need to take the top off of the headlight just like you would when installing angel eyes.
TiAg FTW! |
01-10-2016, 08:05 PM | #4 |
Rep 212
I read that you have to take the wheel well liner off as you would when removing the bumper. The access panel for the turn signal is behind the lining. Some people remove the wheel to make it easier.
01-11-2016, 03:18 PM | #6 |
No 55mph
1623
Rep 8,479
Yes, you need to remove the front inner wheel liners to gain access to rear of lights & replace Turn Signal Bulbs
Just did this last year on my E92 to install LED turns...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-17-2016, 03:52 PM | #7 | |
Rep 686
01-18-2016, 04:56 AM | #9 | |
No 55mph
1623
Rep 8,479
You can get away with just turning the wheel on side you are working on to gain access to the liner 8mm screws, but it's easier if you just take the wheel off to get the liner out. Fairly evident all the screws that need removed... BTW, in that video posted it shows an access panel located in the liner that they removed to get to the bulb? Don't know what year/model cars that panel is on, but it sure isn't on my 09' - I had to remove the liner as described
01-18-2016, 07:33 PM | #11 | ||
Rep 686
