Steering wheel moan.
01-10-2016, 11:41 AM | #1 |
Rep 278
Past couple of days, I've noticed that when I'm driving at low speeds, usually in a parking lot, there's a sound coming from the steering column.
It's hard to really describe it, but it sounds like a moan. I let a tech hear this, and he says it sounds like a pump associated with the steering fluid. That in my car ('10 E90) it's not electronic, and that's what I'm hearing. 1: is anyone here familiar with this (sound)? 2: any idea how involved a repair is? |
01-10-2016, 07:10 PM | #5 | |
Rep 278
01-11-2016, 03:53 AM | #7 |
Rep 503
Drives: e92
01-11-2016, 09:30 AM | #8 |
Rep 259
Flush and fill your PS fluid, you probably have a slow leak under the reservoir. I did it twice with a turkey baster over the course of two weeks. Suck out the fluid and fill it up with new fluid, two total times. It's not a proper complete drain but it will get the job done and most likely solve your moan. Make sure you use the right fluid. Mine was moaning and was low on fluid. Fluid was also brown and in need of a change.
01-11-2016, 10:08 AM | #9 |
Rep 688
If it's the PS Pump moaning then you need to check and if not low then flush your fluid.
The good thing is it's easy to do in our cars with a turkey blaster/siphon and a bottle or two of fluid. Just do it 2-3 times over a few months and you will mostly have new fluid in there by the time you are done. |
01-11-2016, 07:40 PM | #11 | |
Rep 278
01-12-2016, 12:06 PM | #13 |
Rep 3,696
What is the steering column boot that needed lubrication? I'm getting an issue where it sounds like a wire brush is rubbing something, anytime I do a 1/4 turn while the car is stationary or at low speed (Either direction).
01-12-2016, 01:04 PM | #14 | |
Rep 2,109
http://www.amazon.com/Honda-Genuine-.../dp/B006Z9TZ9M There are youtube videos on BMW steering boot squeak fixing, one can reach it from inside the car and lubricate it. A wire brush sound may not be boot. |
