My E90 felt like it was going to explode.
01-11-2016, 06:06 PM | #1 |
Rep 3,141
Got into my car this morning, and started it up. My entire car started shaking abruptly, and my SES light came on. I was like WTF? Couldn't drive more than 40mph, and my rpms didn't move much. I thought I was in the hole for some big $$$$. I took it to my Indy shop who are all former BWW technicians. The owner was a former shop foreman, and now owns his own shop. He diagnosed a engine coil gone bad. It was fixed, and off I went with a bill of $160.00. Car runs great again. He recommended changing my vanos, and thermostat. Thank god for these guys. It really pays to know of a Indy shop that does great work. Thank you. I'm sure the stealership would've said I need a lot more, than the engine coil.
01-11-2016, 08:31 PM | #3 |
Rep 18,801
Depending upon the mileage, replacing all the other coils may be a good idea. However I'm not sure why your Indy recommended replacing the t-stat since it will not leave you stranded, and when failed will throw a SES light, so wait for it, if ever, to fail. BY VANOS he means replace the VANOS solenoids. There is ample evidence on this Forum that cleaning and swapping the solenoids is most times as effective as replacing them. But again, the solenoids with throw a SES light, which is the time you'd investigate either a clean and swap, or if necessary, replacement of one or both of the solenoid units. Preemptively changing parts on the N52 is mostly a waste of money. None of the parts your Indy recommended will leave you stranded in need of a tow.
My 2 cents.
01-11-2016, 09:40 PM | #4 |
Rep 5,016
Yep, it's all relative. Sounds like you're happy and it was a painless process, which is the most important thing. The dealer would have wanted to replace all the coils and maybe the plugs...for about 6 bills. HA!
01-12-2016, 04:07 AM | #5 |
Rep 11,905
I wuv good news stories
01-12-2016, 06:47 PM | #6 |
Rep 3,141
True. My Indy did say it's not urgent to change the thermostat. or the vanos solenoids. He said my SES light will go on. It's then I could check both.
01-12-2016, 06:55 PM | #7 |
Rep 1,818
Happed during my test drive. I knew what it was but played dumb and very concerned. Seller got a new coil, 6 new plugs, and dropped the price to under 15k
Pays to do your homework! |
01-12-2016, 07:11 PM | #8 |
Rep 2,293
I got one coil gone bad. Dealer replaced it under warranty. I asked the service advisor how much would've been if I was out of warranty , she says 700 dollars
I told my indy shop and he laughed. |
01-12-2016, 07:17 PM | #9 | |
Rep 687
He gave me the plugs and wanted to grab my card. It was then that I asked: "how much is it?" "210". I gave him the finger and went to an auto parts store and got the same plugs sans the bmw logo for 12 bucks each 2-pack (so 36). Lesson is: do your homework, shop around. But sometimes the dealer could be used. |
