What to do at 102,000 miles
01-13-2016, 07:15 PM | #1 |
Rep 9
I just got my new to me e90 back from the detail shop and noticed a considerable mpg drop. When I first picked it up 2 weeks ago I couldn't get the computer to move from 26.7 mpg (even in the city) and now after picking it up it dropped to 21.9 I read that at 100k you're supposed to change things such as spark plugs but what else am I suppose to change? Judging by the way the previous owner left her I can assume she didn't touch anything under the hood. I have never done a DIY but always willing to learn. Thanks.
01-13-2016, 07:28 PM | #3 |
Rep 199
that 26.7 mpg is probably averaged over of thousands of miles. It was reset in the shop and showing your driving style numbers now.
btw, no walnut blast for N52K engine |
01-13-2016, 07:33 PM | #4 | |
Rep 9
About to ask but the N52 is the 328i engine? |
01-13-2016, 07:34 PM | #5 |
Rep 182
01-13-2016, 07:36 PM | #6 |
Rep 9
01-13-2016, 07:47 PM | #7 |
Rep 182
01-13-2016, 07:47 PM | #8 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
01-13-2016, 07:59 PM | #9 |
Rep 665
Also, remember that mileage will go down a bit with Federally-mandated winter-blend gasoline plus the engine will run richer until fully warmed up. That combination can affect your mileage by 10-20%.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
01-13-2016, 08:00 PM | #10 |
Touring cars rock
351
Rep 907
Air filter, cabin filter, plugs, transmission fluid, accessory belt & tensioner was what I did (and all the fluids including flushing the power steering). I'm about to also do all the wheel bearings and replace some bushings with PowerFlex bushings to tighten up the front end a bit as it seems to be a bit soft at speed.
I switched to Brisk racing plugs as I had them in my tuned/built bi-turbo Audi S and I love them. They last a LOT longer and I am sure the car is smoother. I also tested the coils and they were all fine. I have been pouring 300ml of LiquiMoly Ceratec into the crank case every 20k now (every fourth change) as well and changing oil every 5000mi with Liqui-Moly 5/30 and my valve train sounds like a new car. I also pour a can of Seafoam into the tank with every 4th tank to keep things nice and clean. |
01-13-2016, 08:02 PM | #11 |
Rep 358
01-13-2016, 08:08 PM | #12 |
Rep 1,849
Ohhhh, young padawan.... you have much to learn.
:smh:
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
01-13-2016, 08:28 PM | #13 |
Rep 358
01-13-2016, 08:59 PM | #14 |
Rep 13,127
Google Mike Miller BMW
download the old school maintenance schedule and read. All fluids , All Filters and plugs would be good start. Maybe the serpentine belt and tensioner. And inspect for oil leaks. |
01-14-2016, 03:01 AM | #16 |
Where'd my VTEC go?
481
Rep 6,067
Stuff that is not tracked by the car's CBS (condition based service) system that you should probably take care of:
-Accessory belt/tensioner/idler pulley -Transmission fluid -Differential fluid -Power steering fluid Do you have any maintenance records at all? The following should have been done at regular mileage/time intervals but if you're not sure if they have been done or not then it might be a good idea to just do them anyway: -Spark plugs -Brake fluid flush -Oil/filter change -Microfilter -Engine air filter -Wouldn't hurt to run a bottle of Techron concentrate through as well (do this before an oil change) Common failures to keep in mind if they haven't been taken care of already: -Water pump/thermostat -Oil filter housing gasket leakage -Oil pan gasket leakage
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
01-14-2016, 08:47 AM | #17 |
Rep 952
Overtime the O2 sensors tend to lose their range and sensitivity. Replacing these on a 100K mile car can often get you back ~2-5% fuel economy.
bone stock
01-14-2016, 12:06 PM | #18 | |
The Replacement for Displacement
22
Rep 126
01-14-2016, 05:59 PM | #19 |
Touring cars rock
351
Rep 907
01-15-2016, 09:25 AM | #22 |
Rep 3,475
