Question about coolant level sensor on bottom of coolant expansion tank
01-15-2016, 11:49 AM | #1 |
Rep 290
I have a small leak on my coolant expansion tank and it seems to be coming from the level sensor. How exactly is the fitting attached to the tank? I'm not talking about the electrical connection to the sensor but the fitting itself. I can rotate it 45 degrees. Is it possible it's just loose and needed tightening?
2011 BMW 335i XDrive Msport (auto)
01-15-2016, 12:03 PM | #3 |
Rep 485
The coolant sensor itself sits in a dry "well" type area and a magnet on the float inside the tank actuates the reed switch in the sensor if the level is too low. The tightness of the sensor fitting will not have any affect how well the tank is sealed. If there's a leak in that area it is the plastic tank itself and not the sensor.
01-15-2016, 09:11 PM | #4 | |
Rep 290
Thx!
01-15-2016, 09:13 PM | #5 | |
Rep 290
01-15-2016, 09:15 PM | #6 |
Rep 186
Get the car all warmed up and you'll probably find the expansion tank will have a tiny spray leak somewhere.
'11 E92, MSport 3 Pedal 3.1L Stroker Z |
01-15-2016, 09:47 PM | #7 |
Rep 762
Expansion tank is $50 and sensor is $16 so your deductible is a wash for parts. Now labor ?Love to know how much they charge when it's out of their pocket vs yours.
