Paddle shifter question's !!!!!
01-23-2016, 11:09 PM | #1 |
Rep 68
I would like to switch my old paddle shifters for new ones is there a DIY on how to change them does anyone know if it's easy? And what paddle shifters would be compatible with my car and steering wheel ? 2009 E90 335i I currently have the stock chrome paddle shifters
02-16-2016, 11:47 PM | #2 |
Rep 2
E9X Push/Pull Shift Paddles to + and - Pull Only Paddles...
Hi there, just completed what you are setting out to accomplish exactly two days ago. Retrofitting LCI single function + and - (pull only) paddles to my M-Sport wheel that had the original 'Push / Pull' (dual function paddles like in your image). Though there are posts on here that will assist you (as far back as 2009) they are a little confusing and lack detail. I have put together a PDF doc that shows (with images) the step by step process required to achieve the desired result. If you have half a brain, know someone with a soldering iron and are not bad on the tools then you're 90% of the way there.
Hope this helps! P.S. My car is a 2007 E93 335i Vert (pre LCI) BMW Paddle Upgrade.pdf Last edited by LuvaBeemer; 02-16-2016 at 11:58 PM.. |
