Need Help Diagnosing an Issue! (2006 530i) Update: Problem Fixed
01-24-2016, 02:18 PM | #1 |
///Project Aura
390
Rep 889
Hello everyone, the 5 series forum (e60) is fairly dead, so since a lot of issues amongst engines are at least somewhat comparable I thought I might as well try my luck here.
We've had the car for nearly 100,000 miles with relatively no issues; now it's around 180,000 miles. Anyway, my mother says the check engine light came on and the car /engine vibrates violently under load--thoughts on things I should check? Thank you. No discernible rough idle, but under acceleration or load while coasting, the car 'stumbles', like it's misfiring. I'd just like to have a rough idea on what to check and go into my shop with prior knowledge--need the car back and operational as quickly as possible! (As does everyone who has an issue with their car, ) Last edited by YouAreMyWorld; 01-26-2016 at 10:06 PM.. |
01-24-2016, 02:24 PM | #2 |
Rep 359
First step is checking the codes first.. if it's a misfire which it seems like it's the case.. I'd check the spark plugs first and coils after.
01-24-2016, 02:30 PM | #4 | |
///Project Aura
390
Rep 889
Spark plugs were changed within the last 10,000 miles. Coils however, I do believe they are due for a change.
My father is taking the car into the shop tomorrow, so I won't be with him. Thus I want to make him as informed as possible. |
01-24-2016, 06:53 PM | #5 |
///Project Aura
390
Rep 889
Update:
I just took the car for a spin myself. Startup was normal and fine, oil level normal, no iDrive notification, but the CEL is on. Driving is fine until acceleration or load, car acts lethargic or 'stumbles' with noticeable vibration. No disconcerting sounds made, but definitely feels like a coil-pack on the outs to me based on the input above. Car drives fine, but anything about/above 3,000rpm makes the aforementioned issue pop up again. Definitely does not seem to be a gearing/transmission issue. Hopefully it is something as minor as this, she seems to be running strong, and has been very reliable--I hope that stretch continues for quite a while more! Anyone else have more input as to what the problem could be, if it's not resolved by installing new coils? Thank you! |
01-25-2016, 12:17 AM | #6 | |
Rep 81
Trust me, go get the code checked asap im sure there are auto stores that scan for free. But you'll never know exactly what the issue is unless you get the code. It could be coils but can also be something to do with intake or obstructed gas flow. |
01-26-2016, 01:10 PM | #7 |
Rep 222
Hi I had a similar issue with my audi a6 when driving the car vibrates alot feels like a bad miss fire when at lights and just idle in neutral car seems fine. Turned out to be the drive shaft.
Hope that helps.... I was told so many things....if engine mounts, plugs, etc |
01-26-2016, 04:52 PM | #8 |
Rep 726
Well from what I gathered I can only assume one of your coil packs when bye bye. I had a coil pack go out on me recently, luckily I carry my scanner in my car so I scanned for codes and found the one that was bad. Went to Autozone bought a new one and it fixed my problem. I then errased the CEL. For the future, invest in an OBD2 scanner. Look into ELM27 on ebay, they are cheap and work great. GL!
2006 Bmw 325xi VMR V715/OE lip/Redlines/Zsp Springs
1999 Eclipse Spyder Gst 16g/264cams/550cc/255lph/corbeau seats/Comp Stage 4 Clutch/ECUflash etc... |
01-26-2016, 05:00 PM | #9 | |
Rep 18,801
01-26-2016, 10:05 PM | #10 | |
///Project Aura
390
Rep 889
01-26-2016, 10:08 PM | #11 |
///Project Aura
390
Rep 889
Update #2:
As it turns out, it was a spark plug. What caused the spark plug to go out as 'quickly' as it did was due to an oil leak from a nearby gasket. Oil seeped into bank five and caused the spark plug to give way. Thank you everyone for all of your responses, I felt confident that it was a rather small issue. The car is running just like new and we've since fixed the small oil leak that caused the spark plug to go bad in the first place. Thanks everyone once again! |
01-27-2016, 05:15 AM | #12 | |
Rep 18,801
Also, do you have more detail regarding the final diagnosis and repair. It sounds like the ring-gasket of the valve cover gasket set that seals the spark plug cavity failed and allowed oil to build up in the spark plug cavity thus causing a misfire. There must have been a serious amount of oil. I still find it difficult to believe unless the oil caused the coil to fail. It certainly was not that the spark plug was oil fouled.
