Weird slight steering vibration
01-25-2016, 07:01 PM | #1 |
Rep 2,016
Hey guys. Just to clear this up: it is not a steering wheel shake. I fixed that problem with new tires and replacing a caliper which was sticking. This is a different problem where my steering wheel has a very slight vibration when it starts to move. As soon as I'm at a stop it goes away. Then as soon as my car starts to move I will feel it in the steering wheel. It's a weird thing. I'm pretty positive it isn't coming from any suspension or wheel/tire item since I got all new parts when figuring out the shake. Also when I put the cat in neutral and rev it , it stays still. Not sure, anyone know?
Instagram~~"alexverdii"~~~
01-25-2016, 07:25 PM | #2 |
Rep 807
Drives: 2011 335is 6MT
01-25-2016, 07:32 PM | #3 |
Rep 2,016
Replaced rotors and calipers. And it meaning my car. Even if I don't give it gas and just roll the vibration will appear. It's slight but any enthusiast would notice it
01-25-2016, 07:35 PM | #5 | |
Rep 2,016
01-25-2016, 07:36 PM | #6 | |
Rep 807
Does the vibration vary with speed? Does the vibration go away if you are rolling (say 10 mph) and you shift to neutral? No x-drive, correct? |
01-25-2016, 07:38 PM | #7 |
Rep 807
Also, did it go away completely after the new tires and brakes, and then come back after some time?
If not, it could just be a bad balance by the tire guy. |
01-25-2016, 08:38 PM | #8 |
Rep 278
Maybe control arm bushings. There's a few suspension components that could cause these symptoms. Depending on your mileage, it may be time for a suspension refresh. As these cars approach 100k, you can definitely feel things loosening up.
01-25-2016, 08:40 PM | #9 | |
Rep 2,016
01-25-2016, 08:41 PM | #10 | |
Rep 2,016
01-25-2016, 08:55 PM | #11 |
Rep 807
01-26-2016, 11:09 AM | #13 |
Rep 3,696
01-26-2016, 11:29 AM | #14 |
Rep 2,016
Checked them all man
01-26-2016, 12:22 PM | #17 | |
Rep 2,016
01-26-2016, 12:59 PM | #18 |
Rep 687
01-26-2016, 01:05 PM | #19 |
Rep 41
I had a slight vibration in the steering wheel that went away when the rear wheel bearings were replaced. Of coarse, they were a screaming banshee by then. You can only turn your radio up so loud before you need to replace!
01-26-2016, 01:11 PM | #20 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
01-26-2016, 05:05 PM | #21 |
Rep 18,806
My car was doing that. I turned out to be the dual-mass flywheel. You can read up on the issue on Bav Auto's website.
01-26-2016, 05:57 PM | #22 |
Rep 687
