02-21-2016, 12:32 PM | #1 |
Rep 587
N55 JB4 map 0 when dropping car off for service?
Have to bring my car in for standard oil change service tmro. Should I put my JB4 on map 0?
If so, how do I assure its on map 0? Not a big fan of switching maps on the new version of JB4. Found it much easier on my N55 335 where it showed you what map you were in on the speedo and tach rather than on the 435 where it just blinks. I don't have the connector to hook up to a laptop..
2017 M4 /// YMB-Blk /// 20” Rohana RFX10 /// 15% Tint /// M-performance Grills /// CF M-Performance Splitters /// CF M-Performance Trunk Spoiler /// CF M-Performance Front Lip /// RW Carbon Side Skirt Exts /// RW Carbon Rear Diffuser ///Color Match Reflectors /// Keyhole Delete /// Euro Shadowline Tails /// AA MidPipe ///
02-21-2016, 05:12 PM | #2 |
Rep 305
Well I change mine to 0 just because if they test drive it I just don't want them rodding my car around on that much power.
For me I just change it on the from the steering wheel, and just move it to 0 on the rpm. |
02-21-2016, 05:46 PM | #3 |
23
Rep 332
Press and hold volume down on your steering wheel for about 5 seconds. You will notice the shift knob flash, you're now on Map 0. To change maps just press volume up to go from 0-1-2 and so on.
02-21-2016, 06:17 PM | #4 |
Rep 4,529
Be sure to drive the car for a short in map 0 before taking it to the dealer so as JB4 is no longer interrogating the can-bus. If not then the canbus monitoring by JB4 may block/impede/corrupt techs attempts to read and write via obd2 port.
Trust me I know as I drove my car to the dealer for service, left it in map 4 and the dealer couldn't install any updates etc. Once I had talk the tech through how to set jb4 to map zero then he took for 15-20min drive in map 0 - it was fine.....
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
02-22-2016, 12:18 PM | #5 | |
BimmerPost Supporting Vendor
4927
Rep 116,037
Mike |
02-22-2016, 02:59 PM | #6 | |
24479
Rep 191,453
When taking the car to the dealership, i recommend removing the JB4
02-22-2016, 09:11 PM | #7 | |
Rep 587
Every time u access it via the down volume button, it always starts on map 0 now? Or does it remember the map you were last on?
02-23-2016, 01:26 AM | #8 |
Rep 4,529
Bmse92
The map settings don't change when the ignition is switched off/on. Hold volume minus button on SW for ant 5s switches Jb4 off / map 0 then pressing volume plus button a number of times gets your preferred map ie 5 presses = map 5. Depending on what FW you are running the shift light will flash 5 times and or the info display in MFD will scrolled on 5 times ie like pushing BC button 5 times.
02-23-2016, 09:11 AM | #9 | |
4927
Rep 116,037
Mike |
02-23-2016, 04:05 PM | #10 |
Rep 587
Ok.. Thanks for clearing that up. Appreciate the help!
02-24-2016, 07:51 AM | #11 |
4927
Rep 116,037
