E93 M Sport lowering at front
03-10-2016, 07:01 AM | #1 |
Rep 278
Hi,
Can anyone point me in the direction of a decent set of lowering springs that will lower the FRONT only, when compared to M Sport suspension? I have an E93 msport and it sits with the usual "front high" look so I'd like for the arch gap at the front to be minimised whilst retaining the same arch gap I have now at the rear. Ideally any kits that dont affect ride/handling much would be what I'm after. Thanks in advance. |
03-10-2016, 07:17 AM | #2 |
Rep 2,445
Drives: 2018 630iGT sport
Eibach Pro will lower the car by about 15-20mm on the front and allegedly 5-10mm on the back.
The rear will drop very slightly, but it's hardly noticeable from stock on an M-sport IMO. You won't find a kit that lowers only the front. |
03-10-2016, 09:02 AM | #4 |
Rep 278
Thanks guys, as long as the front and rear are level. I wouldn't want the rear to be any lower than the front.
I guess it's more difficult on a convertible due to the extra structure, and hence weight, at the rear. But if the kit is only for the vert then it should be okay I guess. Does anyone have any pics of the Eibach Pro kit? Preferably on an E93 |
03-10-2016, 10:06 AM | #5 |
Rep 2,445
Wife's old e93 320 on Eibach pro
03-12-2016, 09:40 AM | #8 |
Rep 3,201
Drives: E92 325i MSport Coupe
If it's front lowering only you want, why not try lowering perches?
http://www.e90post.com/forums/showthread.php?t=523044
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
