05-10-2016, 08:15 AM | #1 |
Rep 796
Hey guys, I thought I would share my experience installing my VRSF DP last night. The unit sent was without defects and I really appreciated the free ceramic coating. Good job VRSF.
Update - iPhone video link - https://instagram.com/p/BFPq1WBx0DU/ Install Difficulty - 2-3/10 V-band Annoyance whilst on the ground in your garage - 7/10 I would recommended you use a lift to avoid some annoyances. Follow the M235i DIY and you will be good to go. The under-tray is different but it is also easier to deal with. Removing the two bolts on the front exhaust hanger behind the flex pipe is a must. Makes life much easier. No need to drop the system. Also, remove the brackets attaching to the stock DP, then remove the studs that go into the housing. Once the bracket is fully out you'll have much more room, I installed the studs right back in, this is a must as they are an integral component. I found the new belly plate to be much easier to deal with. Gone are the days of 40 8mm screws and fiddling with plastic. You just drop the plate (8 large bolts, 10ish 8mm's) and your good to go. The O2 sensor clips are under the engine cover, you need to remove the foam deadening to properly reach them. Or peel it up out of the way. The grey 02 sensor wire has less length when installed vs the black wire. To ensure the wire has enough room and won't contact the manifold I would check fitment when the top turbo v-band is loose and has some play. --------------- Sound impression - Sweet baby Jesus, you have to hear it in person to understand. Cold startup is pretty loud but is over quick, idle is great, reminds me of the early td05 WRX catless + catback spool. Slight blips and movement produce a whistle. Small turbos are always awake. The low throttle spool itself is much more distinct than my full catless non res n54. It sounds like a DBB unit compared to the n54. It's much lower and has hints of that wonderful NA howl we all love, without the rasp. This is louder and has a different tone vs a catless m235i. Driving impressions - The overrun burble is just plain fun, it doesn't sound like a first date restroom run. Everything is turned to 11. At highway speed in comfort you wouldn't know it was catless, in sport and sport + you hear a little more boom but I wouldn't consider this "drone" at all. This is where I actually enjoy active sound. You can appreciate its noise cancelling properties. The downshifts are fierce and everything feels twice as visceral, I'm not exaggerating. Performance wise I can feel a difference down low, the response is very quick. I'm sure without a tune gains are around 10-15ish so it's obviously not life changing. The sound however....is. Overall I honestly don't see why spending your hard earned money on the MPE is a good idea. Unless you absolutely cannot run an aftermarket DP. If you gave it to me I probably wouldn't run it in conjunction. Besides weight savings In no way would the MPE alone add more flavor. The car now sounds like the m2 safety car videos we've been hearing. The stock catback is a really nice unit and will probably flow enough for any amount of power we can throw at it. CEL notes, without a tune I will expect it to pop up around 100 miles as explained in another thread. I have the A seventy-four DP fix that I will install today. I'll provide an update after some miles. All I can say is DO IT, do it now.... |
05-10-2016, 11:12 AM | #4 | |
Rep 796
05-11-2016, 03:23 PM | #5 |
Rep 542
Nice. Waiting for an update on the CEL/DP fix..
-c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
05-11-2016, 06:32 PM | #7 | |
Rep 796
05-13-2016, 08:19 AM | #10 | |
Rep 542
-c
05-13-2016, 11:54 AM | #11 | |
Rep 796
I hope I don't step on any toes moderators. I'm just trying to help someone out. N55 DIY- http://www.******.ca/wp-content/uplo...G-iOS2-SIM.pdf |
05-14-2016, 08:13 AM | #13 | |
Rep 542
-c
05-14-2016, 01:15 PM | #14 | ||
Rep 796
subliminalaudio315.50 |
05-14-2016, 02:25 PM | #15 | |||
Rep 542
Thanks -c
05-15-2016, 07:58 PM | #16 |
Rep 1,922
Drives: 2011 e91
Any luck with the O2 eliminator? Are there any codes hidden that don't throw the CEL? Did you cut and splice the factory harness?
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
05-15-2016, 08:07 PM | #17 | |
Rep 796
It splices into the grey rear 02 sensor on the harness side. |
05-15-2016, 09:11 PM | #18 | |
Rep 1,922
Drives: 2011 e91
2011 E91
05-16-2016, 12:10 PM | #19 | ||
Rep 796
05-16-2016, 01:33 PM | #20 |
Rep 607
Drives: 2019 BMW M2 Competition
Hopefully a tune will catless DP will delete the CEL. Like the JB4 on my F22. Expect the same with the M2 being out for a while.
2019 F87 M2C, Long Beach Blue, Exec, 6MT 2016 F87 M2 - Sold 9/2018 2014 F22 M235i - Sold 5/2016. |
05-16-2016, 02:33 PM | #21 | |
Rep 796
05-16-2016, 06:43 PM | #22 |
Rep 103
this is for the canflap module but I believe the jb4 autoclear works the same way. it doesnt auto clear all codes. post 182
http://www.n54tech.com/forums/showth...t=28714&page=8 |
