E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Steering wheel trim
Reply
      05-21-2016, 08:39 AM   #1
JackHerring
JackHerring's Avatar
Drives: E92 325i
Steering wheel trim
So finally got around to ordering a re trimmed steering wheel with Jack at royal steering wheels, really nice fella, will be picking up the wheel in a week or so, but now the problem is my shabby wheel trim, be silly not to get that sorted when putting on a new wheel. So the question is, wheres the best place to get one from, looking for just a plain piece of trim, without the 'M' badge, as my car is a SE, and preferably without the silver trims down the side, just plain black. Also, are all pieces of trim the same? or are they a different fit for the Msport wheel and the SE wheel? Any help would be greatly appreciated.
      05-21-2016, 08:52 AM   #2
Germanwheels
Drives: E90
M sport and SE trim are different shape so will have to be the SE that you go for, I've always wondered if it's possible to refurb it as surely every piece of this trim ever made is shabby due to the finish it has.
      05-21-2016, 10:23 AM   #3
Phil325i
Phil325i's Avatar
United Kingdom
624
Drives: E92 325i MSport Coupe
Do it yourself! I bought this for mine:
http://www.ebay.co.uk/itm/1306604579...%3AMEBIDX%3AIT
The plastic trim piece is easy to take off the steering wheel, then you can form the wrap onto it quite easily. Use of a hairdryer helps you stretch it where needed. I'm no expert but I was really pleased with the result. Cheap fix.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      05-21-2016, 10:28 AM   #4
JackHerring
Drives: E92 325i
I'm definitely leaning that way, i have a can of Plasti dip, so might give it a once over with that. Cant justify paying £50+ for a piece of trim when every one seems to be doing a decent job by themselves.
      05-21-2016, 03:18 PM   #5
BMW-330i
United Kingdom
46
Drives: BMW 06 330i M-Sport
Was this a good match for the OEM color finish?
I've currently got a duffed up aircon/climate surround and this bit of plastic costs eighty quid from the dealer to replace. Seems BMW picks there prices out of the air when it comes to interior plastic trims.
      05-21-2016, 04:03 PM   #6
BMW-330i
United Kingdom
46
Found this video on YouTube, it may be handy
https://youtu.be/Ddij3iddyZ0
      05-21-2016, 05:05 PM   #7
ben-e92
ben-e92's Avatar
24
Drives: E92 325i
Went Jack did my steering wheel he refurbished my trim at the same time, might be worth asking him
Ben
      05-22-2016, 07:25 AM   #8
Phil325i
Phil325i's Avatar
United Kingdom
624
Yes.
      05-22-2016, 10:58 AM   #9
JackHerring
Drives: E92 325i
Ordered some Matt Black wrap from ebay, so hopefully it will look the part.
      06-07-2016, 07:33 AM   #10
EddyC01
Drives: Looking for an E93 335i
Would be keen to know which worked best, the Plasti dip or the wrap?
I had previously seen some posts suggesting Rust-Oleum flat black but it doesn't appear to be available in the UK, so looking for the next best option!
      06-07-2016, 07:41 AM   #11
PTMedg
Drives: 09' E93 335i
2009 BMW 335i  [0.00]
Name:  CF Steering Wheel Trim.jpg
The wrap isn't too difficult, I went with CF. The tips on the top were the hardest part, but once it get installed you will never notice the slight imperfections.
Video on the Wrap
Removal threads i referenced
http://www.e90post.com/forums/showthread.php?t=243169
http://www.e90post.com/forums/showthread.php?t=575763
      06-07-2016, 07:48 AM   #12
Phil325i
Phil325i's Avatar
United Kingdom
624
Can't speak for plasti-dip but this is what my matt black wrap looks like:
Name:  P1060092 small.jpg
      06-07-2016, 05:10 PM   #13
JackHerring
Drives: E92 325i
I ended up sanding down the trim and spray painting it.
      06-08-2016, 10:34 AM   #14
EddyC01
Thanks for the pictures guys, they both look great! I want to stick with the OEM look so will either got for the matt wrap of spray paint.
@JackHerring you haven't got a picture by any chance? and did you use Plasti dip?
      06-08-2016, 01:21 PM   #15
JackHerring
Drives: E92 325i
No, didn't use plastidip, grabbed some Spray paint from Wickes.
      06-09-2016, 11:38 AM   #16
EddyC01
It looks like a great colour match from the picture, does it match the surround of the gear stick or are you likely to be spraying that as well (assuming you have an auto)?
The only Matt Black paint I can see on the Wickes website is the heat shield stuff: http://www.wickes.co.uk/Wickes-Heat-...400ml/p/602112
Is that it?
      06-09-2016, 05:20 PM   #17
JackHerring
Drives: E92 325i
Is that it?
This is the stuff I used.. Something like £8. I sanded the trim back to the plastic, took the rubber stuff completely off, and it's a perfect match, matches the button etc.
      06-10-2016, 10:50 AM   #18
nik patel
nik patel's Avatar
31
Drives: BMW 330d M Sport Pro G20
My mate has used Jack to do his steering well and we found him very good.
Nik
      06-13-2016, 08:24 AM   #19
MEGA
Dieseasal
MEGA's Avatar
United Kingdom
204
Drives: LCI E92 335d M-Sport
Jack is great, another recommendation for him had three wheels from him.
Sand and spray it! Easy to remove and it's f--ked now so what's the worse that happens? You still need to replace it?
Nice easy DIY to try ..
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport
Reply
e90post
