05-21-2016, 09:19 PM | #1 |
Rep 2,640
2013 F30 335i xDrive JB4 1/4 mile
Mods are:
ER chargepipe ER TIC chargepipe ER 3.5" catless DP Borla ATAK Dinan intake JB4 stage 2 map 5 94 octane Launched in 2nd gear. Brake boost 2500-3000rpm because 1st gear is useless. (8AT) I'm very surprised to run this time with stock 19s 403M, total tire and wheel weight was 54lbs each. I can probably hit low 12s if I had lighter wheels. Had continental DWS staggered. |
05-27-2016, 08:03 PM | #4 |
Rep 2,640
11-20-2016, 05:20 AM | #6 |
Moon Parasite
655
Rep 1,336
Missed your thread originally chaungo . Very nice time on your run. Do you know where you're at power wise with the current build ?
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
11-20-2016, 11:24 AM | #7 | |
Rep 2,640
I had 12.5-14psi when I did this run, it was in map 5 so it was not consistent. I believe with my current setup now, I could probably hit 12.3 and lower
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
11-20-2016, 03:42 PM | #8 |
Rep 456
Thanks for posting your slip. As nice as 1/4 mile times are, I consider the trap-speed a better indication of power as too much can affect the time. 109.32mph is definitely moving! I bet you have 110-112 in you!
11-20-2016, 06:14 PM | #9 | |
Rep 2,640
I believe I can hit 115mph, lighter wheels and dedicated rubber plays a nice part in it. I recently shaved off 10lbs per wheel and I'm slipping alot with my all seasons, so with sticky tires, I think F30s are able to hit 115mph on stock turbo. |
11-20-2016, 09:14 PM | #10 |
Rep 175
Any plans for a track tire/wheel ?
13' 335xi PWG M-Sport 8spd - BM3, CTS Turbo FBO, H&R Sport Springs + Spacers, BMW MPE
11-20-2016, 09:35 PM | #11 |
Rep 2,640
11-21-2016, 04:59 AM | #12 | |
Moon Parasite
655
Rep 1,336
I just need to find a day to travel back to the 1/4 mile and hopefully get more than one run. 1/2 mile was fun though.
11-21-2016, 07:52 AM | #13 |
Rep 2,640
I swapped my contis for AS3+ and they're only good for track, not drag unfortunately as I had less grip from launching.
11-21-2016, 02:10 PM | #14 |
Moon Parasite
655
Rep 1,336
Liking the Conti's so far with about 2K on them.
