F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Help with fault codes
proTUNING Freaks
      05-27-2016, 03:55 AM   #1
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
On my '12 328i I am getting several fault codes that I can't figure out. I was hoping someone here might be able to help out.
Things I have coded:
halos too 100% with headlights on
Front corner lights off (turn signals still flash)
M Performance splash on cluster
Removed disclaimers (PDC & I-Drive)
DVD in motion
Phone ringtone
Separate cluster/ambient brightness control
Turn signals set to 5
TPMS temp & pressure on I-Drive
A.S.S. remember last setting
A.S.S. disabled notification on cluster
Actual speed on cluster
I have factory:
Xenons with auto leveling
Auto high beam assist
LED Lighting package
These are the fault codes I'm getting on buddies Autologic reader:
Front Electronic Module (FEM)
(FEM_20)
8041C3 Lamp Mapping Failed
D90D37 Interior Lighting Unit (ILE) Incorrect Version Installed
High-Beam Assistant (FLA) (FLA_20)
E0EC07 KOMBI Interface (kilometre Reading/range, 0x330) Signal Invalid
Central Gateway Module (ZGW)
(ZGW_1)
CD0487 ZGW Synchronization process for FlexRay failed
CRASH SAFETY MODULE (AIRBAG) (ACSM4)
930AB3 Indicator lamp for front passenger airbag Deactivation Short Circuit to B+
DIGITAL MOTOR ELECTRONICS (MOTOR)
(MEVD1724)
195013 Fuel Differential Pressure sensor, tank ventilation system, working area: absolute pressure too low
I do know that the cornering function (fogs) only seem to work when I turn to the left, when I turn to the right my right fog does not come on like it should.
:wave:
      08-20-2017, 03:34 PM   #2
gotomoto
gotomoto's Avatar
41
Drives: F30 3.20ied
hey. did you end up fixing these at some point?
f30post
