F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > 340i launch control?
proTUNING Freaks
      05-27-2016, 08:11 AM   #1
mtx450
mtx450's Avatar
Drives: 2011 E90 M3 ZCP
2011 BMW M3  [0.00]
Has anyone gotten this to work? I understand the process and can't figure out how to make it work. I also only have 2100 miles on my car, so I'm not sure if there is a 5000km (3100 miles) rule or not before it activates?
And yes, because I know someone is going to ask. I'm in Sports+, shifter in S, and holding brake/pushing throttle past resistance point.
      05-27-2016, 08:05 PM   #2
HitmanHearns
Drives: 14' Infiniti Q50 / 16' Audi A4
I've been wondering the same thing. I'm at 200 miles so still waiting out. Only
thing I found was this in the instruction manual.
      05-28-2016, 09:13 AM   #3
DocB
DocB's Avatar
Drives: 2020 M340i
The only cool thing about launch control is the little checkered flag that comes up in the dash. Everyone does it once.
2003 328i
2006 330i
2014 328i
2015 435 GC
2015 X1
2016 X1
2018 ///M2
2020 M340i
      05-28-2016, 12:36 PM   #4
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
I'll be giving it another shot later tonight. I'm only getting wheel spin when I try it which makes me think I'm not hitting the brakes hard enough.
      06-03-2016, 01:18 PM   #5
Paul_M3
Paul_M3's Avatar
56
Drives: 2018 Imola Red M3
just want to confirm that you know the resistance point is the little button after you floor the gas. you want to hold the brakes hard then floor the gas and press the button and keep the gas pedal there to keep launch control going
2018 BMW M3 ZCP- Imola Red
Follow me on Instagram: @hsdvisuals
      06-04-2016, 01:13 AM   #6
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
Yep, definitely pushing it past the resistance point.
I literally tried it like 6 times tonight, and cannot get it to work at all. I'm definitely pushing the brake super hard and the throttle all the way. Shifter in D/S and Sport+. No dice.
      06-06-2016, 12:16 AM   #7
Paul_M3
Paul_M3's Avatar
56
start fresh... you have passed the break in period listed in your manual?
next, you have driven without the engine switching off (even with auto stop/start) for 5/6 miles...
next, the normal sport+ switch shifter the left into S gears and brake all the way then floor it passed the button..
do you meet all these reqs for LC?
      06-06-2016, 06:01 AM   #8
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
I don't see any break in period listed for LC. There is a regular break in period of 1400 miles which has definitely been completed.
All other steps are being followed. I even checked the module in E-Sys and can confirm LC is active.
      06-14-2016, 01:45 PM   #9
JamRWS6
Drives: 2022 X3M Competition
I've gotten it to activate several times without issue.
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
      06-14-2016, 04:02 PM   #10
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
How many miles do you have? I'm going to try it again tonight. I'm at 3k miles now.
      06-17-2016, 12:05 AM   #11
cesarortiz23
cesarortiz23's Avatar
Drives: bmw m2 lci
I do it on my 335i all the time
You have to press the brake pretty DANM hard lol
Also make sure your car is in full warm temperatures
and the checkered flags should come on
nothing special about the launch control on these things
bmw m2
      06-17-2016, 10:23 AM   #12
poorguy
Drives: red
I've gotten it to activate several times without issue too
      06-24-2016, 06:02 PM   #13
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
Make sure to step on the gas hard and you will feel a clicking noise
      06-24-2016, 07:15 PM   #14
DocB
DocB's Avatar
Drives: 2020 M340i
Not worth it and not good for the car either.
2003 328i
2006 330i
2014 328i
2015 435 GC
2015 X1
2016 X1
2018 ///M2
2020 M340i
      07-23-2016, 07:47 AM   #15
JamRWS6
I have 6k now but was able to activate in the 2k range. I did not try previously. I actually find it much easier to activate this way and it seems to activate every time.
- Car does need to be up to temperature so don't try it when the car is cold.
1. Press DSC button once ( puts car in "Traction" mode)
2. Pull shifter over into Sport
3. Stomp the brake nice and hard
4. Immediately at the end of 3 push the accelerator very quickly past the kick down switch (i.e. To the floor).
5. Indicates active in the instrument cluster and you're ready to go.
Works every time as long as the car is up to temp. To me this is easier than trying to put in Sport+ as it saves button pushing since I'm not in that mode. The traction mode is also seemingly using Comfort settings on the dampers which helps with traction over the Sport setting ( I have the M adaptive suspension). This also keeps you out of Sport+ and doesn't force you to do the shifting yourself.
- 2022 X3M Comp
      04-09-2017, 11:42 PM   #16
drummerlauw
drummerlauw's Avatar
80
Drives: 2016 340i. 2020 M340i
My car doesn't have navigation, is that why i don't see any checker flag on the dash??
      04-10-2017, 09:48 AM   #17
mtx450
mtx450's Avatar
2011 BMW M3  [0.00]
I eventually got it to work, I don't think I was doing it right initially (even though I read the steps like 400 times). You should see the checker flag, even without navigation.
      04-10-2017, 12:57 PM   #18
drummerlauw
80
I still can't get it to work...
1. Engine is warm (being driven for 40 miles or so)
2. Sport +
3. Shift lever into "S" Mode
4. Traction Off
5. Hold the brake hard
6. Press gas all the way
7. No checker flag........
Any wrong step? Any timing error?
All i care is seeing that checker flag. hahaha. It still pulls pretty darn hard.
      04-11-2017, 05:33 AM   #19
Vojta89
Vojta89's Avatar
Czech_Republic
147
Drives: 2018 F87 M2 Competition
2. Sport +
4. Traction Off
0. Turn on engine and switch off Auto Start/Stop (should look like this )
1. Warm up engine (drive at least 10 km/6 miles without turning off engine even auto start/stop)
2. Engine is warm
3. Sport +
4. Shift lever into "S" Mode
6. Press gas all the way (kick down)
7. checker flag
8. GO (within 3 seconds)
Mine works
2009-2011 E90 320si street/track car - SOLD ; 2010-2016 E92 330d LCI street car - SOLD ; 2016-2018 F30 335d LCI street car - SOLD
2011-2021 E46 M3 track car - SOLD 2018-???? F87 M2 Competition street/track day car
My Instagram
      04-18-2017, 01:40 AM   #20
mannymazz
Drives: 440
Biggest issue I seen with people is they don't allow car to warmup enough and don't depress brake hard enough.
      04-24-2017, 11:15 AM   #21
cptcrunch
Captain Crunch
cptcrunch's Avatar
168
Drives: 2016 340i
Never knew about the 6 mile requirement. Could be a problem if people wanted to use it on a drag strip.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno
Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade
      04-27-2017, 03:20 PM   #22
jalkster
Drives: X3MC
yeah big problem... this answered why I couldnt get it
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T
f30post
