05-30-2016, 10:36 PM | #1 |
Rep 28
JB4 now... what intake and downpipes?
Hey guys. I just got a 2013 335i four door. I just purchased the JB4 chip and decided I wanted to intake and downpipes as well in one big swoop. Anybody have any suggestions what are the best intakes and downpipes?
1. Best overall? 2. Best bang for the buck? 3. Are either of these going to throw an error code on the dash? I don't know where to start. Thanks guys! |
05-30-2016, 11:55 PM | #3 |
Rep 141
I would get down pipes. CATLESS or CATTED , depends on what you want. But evolution racewerks is the way to go. You could instantly feel the gains with the JB4 and sounds great with any exhaust including stock.
BMS is cheap and sounds amazing. Love the swoooshhhh noise it makes. And very easy to install. |
05-31-2016, 07:04 AM | #4 | |
Rep 2,651
ER catless will throw a CEL on the dash, but since you have your JB4 (stage 2 I hope) you can have it autoclear. |
05-31-2016, 10:53 AM | #6 |
Rep 5,776
It will auto clear the codes-you can also set it to off if you want to see the codes. You also should consider a charge pipe as the increased boost puts more stress on a weak part....here is my review of the VRSF DP.
http://f30.bimmerpost.com/forums/sho....php?t=1224100
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
05-31-2016, 11:48 AM | #7 | |
Rep 2,651
IMO I would get the TIC chargepipe too as you have to drop intercooler anyways. |
05-31-2016, 01:37 PM | #8 |
Rep 28
[QUOTE=chaungo;20025497]Yes, just make sure it's on Map 4 (logging mode
drop intercooler? what does that mean? sorry I must eat my humble pie and ask what you mean by that lol |
05-31-2016, 02:14 PM | #9 |
Rep 2,651
[QUOTE=mxrider3355;20026149]To install new chargepipes, it's easier if you take off the intercooler and put new chargepipes in, so that's why I recommend buying both chargepipes so you don't have to do it again.
05-31-2016, 02:22 PM | #10 |
Rep 5,776
[QUOTE=chaungo;20026391]To install the cp you do not have to remove the intercooler...it needs to be loosened and moved a few inches.
05-31-2016, 02:31 PM | #11 |
Rep 2,651
[QUOTE=jgoens;20026435]On the xDrive at least, you had to remove the intercooler (literally 2 bolts and slide down) or else no room, and you'll definitely need to drop it for TIC chargepipe. Also was a bitch to clip the CP back on the intercooler.
05-31-2016, 03:26 PM | #12 |
Rep 5,776
[QUOTE=chaungo;20026505]Yeah, might be different for Xdrive. I agree the hardest part was getting the lower portion to fit correctly--just an odd angle and breaks the arm shoving that bitch in. Mine did not seat right the first time and popped off on my first test drive. Yeah, the IC is easy to slide out.
05-31-2016, 04:52 PM | #13 |
Pace Car Driver
1557
Rep 3,166
mxrider3355
Come on bro, your question belongs here: http://f30.bimmerpost.com/forums/forumdisplay.php?f=421 |
06-01-2016, 12:42 PM | #14 |
BimmerPost Supporting Vendor
24479
Rep 191,453
Most popular intakes Injen and BMS
Downpipes Wagner, VRSF and Evolution Racewerks Wagner DP, made in Germany very high quality downpipe with precise fitment for a very reasonable price Best bang for the buck? VRSF. unbeatable price, ceramic coated finish + perfect fitment Evolution Racewerks is a very high quality DP made in the US, but will cost more than the 2 other options above You wont get any CEL light because the JB4 hides it
06-01-2016, 11:21 PM | #15 |
2JZ-GTE
3072
Rep 4,020
my car needs a downpipe
It's slow. It needs power. |
06-02-2016, 10:40 AM | #16 |
4927
Rep 116,037
06-06-2016, 08:16 AM | #17 |
Rep 66
Drives: 335i X drive
any concerns with the open element filters sucking in hot air vs the stock that keeps most of that engine temp out?
From an engineering stand point seems best to just upgrade the filter in the stock air box to keep it as cool as it can be or am I missing something here? |
06-06-2016, 05:07 PM | #18 |
Rep 832
Drives: 2019 G01 X3
Anyone know if JB4 + catless DP passes OBD-II emissions tests?
06-06-2016, 06:28 PM | #19 |
Rep 4,529
OP
Oem air box cw Afe dry drop in panel filter and Afe das air scoop - works well in terms of helping throttle response and checking IATs BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-06-2016, 09:16 PM | #20 | |
Rep 945
