Sourcing N54 Downpipes in UK
06-28-2016, 07:30 AM | #1 |
Rep 15
Hi All,
I'm looking for some CATTED downpipes for my N54 335i in the UK. What brand are people generally going with now that AR have (allegedly) gone bust? I have searched extensively and AR seemed to be the only pipes that consistently got good reviews for fitting etc. Thanks, TT Last edited by twintub; 06-28-2016 at 08:20 AM.. |
06-28-2016, 08:12 AM | #2 |
Rep 972
AR went bust? really? wow
why not go catless?
2016 M140i
07 E90 335i: JB4, Trebila BEF, BMS DCI, VRSF DPs, Scoops, 19" CSL Reps, 5" ETS FMIC, VTT Inlets, BMS CP, HKS BOV, BMS Meth Injection - sold |
06-28-2016, 08:22 AM | #3 |
Rep 15
Apparently....(I have no way to verify this I hasten to add).
I thought catted are needed to pass roadside emissions and MOT etc. Also I read that catless can cause fault codes etc (even with JB "fix") and I want to avoid fault codes. |
06-28-2016, 08:26 AM | #4 | |
Rep 3,312
If keeping the secondary CATs in place then you can remove the downpipe ones with no issues to MOT. Others have passed. With the JB4 set to autoclear faults I do not get the fault code coming up on the dash.
06-28-2016, 09:55 AM | #5 |
Rep 972
Just had my MOT last week. It passed with zero advisories (although I took the car for a thrash before hand - this may not even have been necessary). Also ive never had any codes or lights due to DP's with JB4.
2016 M140i
06-28-2016, 10:35 AM | #6 |
Rep 15
OK catless it is.
Looking at reviews it seems that BMS, VRSF and COBB pipes seem to get reviews for fitment. However, many of the VRSF video clips sound a bit "raspy" - have any VRSF users found this? The COBB videos sound much better to my ear...? |
06-28-2016, 11:38 AM | #7 |
Rep 972
I got Vrsf. Mine do sound raspy to be honest but it's mainly when the car is cold. Once warmed up the raspiness cuts down. I like the raspiness though so doesn't bother me.
06-28-2016, 01:36 PM | #8 |
Rep 49
I have some bought them from Birds had them on the car for about 4000 miles sounded amazing gave a noticeable increase in torque. Took them off as had BMW warranty am in Crowthorne Berkshire if you are interested will look what I paid for them but £350 and they are yours.
07-12-2016, 06:25 AM | #9 |
Rep 15
So after looking into this I still want a set of CATTED pipes. Mainly because I don't want any smell issues.
But it seems like its no longer possible to get any catted pipes for RHD cars. Does anyone know of a source? Thanks, TT |
07-12-2016, 06:40 AM | #10 |
Rep 972
... there is no smell if you decat the primaries.
2016 M140i
07-13-2016, 03:53 AM | #12 |
Rep 968
Have you looked at custom systems or some one like Torque Technique who can make custom exhaust parts.
http://torquetechnique.co.uk/wordpress/ |
07-13-2016, 05:12 AM | #13 |
Rep 308
I don't experience any smells...both primary and secondary have been removed!
If you want to keep it cheap get them to gut the current cats, you know for sure fitment will be fine...although I had no issues with VRSF DP's
Jb4 with Trebila BEF,vargas stage 2+ turbos, vrsf dp's, vrsf cp with tial bov, vrfs 7" fmic, EOS PI with BMS PI controller, RB Inlets and Outlets, bms meth kit, BMS DCI, miltek cat back, bms occ,3.5 tmap, ngk 5992 plugs, HSD coilovers, M3 rear subframe, diff, drive shafts , suspension and brakes.
07-13-2016, 08:43 AM | #14 |
Rep 3,312
I can smell the petrol more but that's probably because I've decatted both primary/secondary and only got a single small backbox.
I've got Wagners decatted and they fit well.
07-13-2016, 09:24 AM | #15 | |
Rep 2,343
Even with cats you will get that on cold startup with the Open loop and the warming cycle. As you know the warm up cycle can be disabled with a flash tune. There's no more smell from a catless DP car with primary cats than a full catted car. That's proven by getting through the MOT.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
07-13-2016, 09:32 AM | #16 |
Rep 15
Thanks for your reply guys, but its safe to say that there are mixed opinions on smell and there is clearly no firm answer. Getting through an MOT does not mean there cannot be more smell.
I'm really hoping someone knows of a supplier of catted pipes (and I don't want to have a custom one made)... Thanks. TT |
07-13-2016, 10:25 AM | #17 | |
Rep 3,312
07-13-2016, 10:28 AM | #18 | |
Rep 3,312
If you are running the standard system then most definitely catless will be fine with no issues of smell or MOT emissions failure as the secondary cats will still be in place.
07-13-2016, 10:29 AM | #19 |
Rep 972
^^^ This. With a standard exhaust set up there will be no smell. At the end of the day its down to preferance and I appreciate your logic. I just wouldnt hold my breath is all. And its a dam good mod to do as well.
2016 M140i
07-13-2016, 11:21 AM | #20 |
Rep 15
I have a stock exhaust. Again thanks for the input but for every 100 posts that say there will be no smell with this setup, there are a 100 posts that say there will!
07-13-2016, 11:22 AM | #21 |
Rep 2,343
Well I'd be very surprised if there is smell as the test means HCs need to be below 200 parts per million. Not sure what the human nose can detect and true that figure does go out of the window when you floor it.
I think Gangzoom may have had high flow cats. You could contact him to see what he did.
