Classifieds Section > Sponsors Classifieds > HP Autosport BMW F87 M2 Adjustable Swaybar Endlinks
      07-04-2016, 06:32 PM   #1
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
Smile HP Autosport BMW F87 M2 Adjustable Swaybar Endlinks
When you lower the vehicle, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autosport is happy to introduce adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. HP Autosport end links are adjustable while on the vehicle.
The length needed may vary if you are running aftermarket struts as some manufacturers alter the location of the mounting tab.
$159.99
Order here:
https://hpautosport.com/product/hp-a...ybar-endlinks/
      09-05-2016, 09:54 PM   #2
HP Autosport
Drives: F80 M3
in stock!
      09-10-2016, 05:23 PM   #3
HP Autosport
Drives: F80 M3
In stock
      09-15-2016, 03:38 PM   #4
HP Autosport
Drives: F80 M3
bump
      09-26-2016, 10:43 AM   #5
HP Autosport
Drives: F80 M3
bump
      09-30-2016, 10:46 AM   #6
HP Autosport
Drives: F80 M3
bump
      10-07-2016, 01:06 PM   #7
HP Autosport
Drives: F80 M3
bump
      10-11-2016, 03:42 PM   #8
HP Autosport
Drives: F80 M3
bump
      10-14-2016, 11:53 AM   #9
HP Autosport
Drives: F80 M3
bump
      10-18-2016, 12:04 PM   #10
HP Autosport
Drives: F80 M3
bump
      10-21-2016, 06:35 PM   #11
HP Autosport
Drives: F80 M3
bump
      10-26-2016, 03:52 PM   #12
HP Autosport
Drives: F80 M3
bump
      10-31-2016, 10:42 AM   #13
HP Autosport
Drives: F80 M3
bump
      11-04-2016, 05:55 PM   #14
HP Autosport
Drives: F80 M3
bump
      11-08-2016, 11:43 AM   #15
HP Autosport
Drives: F80 M3
bump
      11-13-2016, 07:53 PM   #16
HP Autosport
Drives: F80 M3
in stock!
      11-18-2016, 11:02 AM   #17
HP Autosport
Drives: F80 M3
bump
      11-22-2016, 01:48 PM   #18
HP Autosport
Drives: F80 M3
bump
      11-28-2016, 11:40 AM   #19
HP Autosport
Drives: F80 M3
Cyber Monday Free shipping in US48. Shipping charges will be refunded after confirmation of your order and 10% off
      12-01-2016, 05:29 PM   #20
HP Autosport
Drives: F80 M3
Cyber Week 10% off!
      12-04-2016, 12:32 AM   #21
HP Autosport
Drives: F80 M3
in stock!
      12-07-2016, 05:18 PM   #22
HP Autosport
Drives: F80 M3
bump
m2
