Classifieds Section > Sponsors Classifieds > HP Autosport ||Macht Schnell Competition Wheel Spacer Kit
      07-04-2016, 06:35 PM   #1
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
Smile HP Autosport ||Macht Schnell Competition Wheel Spacer Kit
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders.
Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US.
Competition Wheel Spacer kit Features:
- Machined from 6061-T6 aerospace aluminum
- Chamfered edges allows installation & removal quick and easy
- Black anodized finish for additional strength and corrosion/wear resistance
- Improve handling by reducing body roll with a wider wheel base
- Included zinc plated corrosion-resistant wheel fasteners
Competition Wheel Spacer kit Contents:
- (2) Competition Wheel Spacers
- (10) extended-length zinc plated coated wheel fasteners
Price starts at $49
Order here:
http://www.hpashop.com/Macht-Schnell...pacers-bmw.htm
      09-05-2016, 09:53 PM   #2
HP Autosport
Drives: F80 M3
bump
      09-09-2016, 04:45 PM   #3
HP Autosport
Drives: F80 M3
bump
      09-15-2016, 03:36 PM   #4
HP Autosport
Drives: F80 M3
bump
      09-26-2016, 10:41 AM   #5
HP Autosport
Drives: F80 M3
bump
      09-30-2016, 10:42 AM   #6
HP Autosport
Drives: F80 M3
bump
      10-07-2016, 01:04 PM   #7
HP Autosport
Drives: F80 M3
bump
      10-11-2016, 03:41 PM   #8
HP Autosport
Drives: F80 M3
bump
      10-14-2016, 11:52 AM   #9
HP Autosport
Drives: F80 M3
bump
      10-18-2016, 12:03 PM   #10
HP Autosport
Drives: F80 M3
bump
      10-21-2016, 06:34 PM   #11
HP Autosport
Drives: F80 M3
bump
      10-26-2016, 11:28 AM   #12
HP Autosport
Drives: F80 M3
bump
      10-31-2016, 10:41 AM   #13
HP Autosport
Drives: F80 M3
bump
      11-04-2016, 05:42 PM   #14
HP Autosport
Drives: F80 M3
bump
      11-08-2016, 11:35 AM   #15
HP Autosport
Drives: F80 M3
bump
      11-14-2016, 10:32 AM   #16
HP Autosport
Drives: F80 M3
bump
      11-18-2016, 11:12 AM   #17
HP Autosport
Drives: F80 M3
bump
      11-22-2016, 01:49 PM   #18
HP Autosport
Drives: F80 M3
bump
      11-26-2016, 07:42 AM   #19
M2GB
Drives: 911 and M2
Originally Posted by HP Autosport View Post
bump
Hello
Do you have 10mm spacers with bolts for the M2? Is the optimum set up with eibach pro springs?
Thanks
      11-27-2016, 10:58 PM   #20
HP Autosport
Drives: F80 M3
Originally Posted by M2GB View Post
Hello
Thanks
Go the the link in post#1.
Yes, select quantity two of the 10mm spacers and 14mm stud size and you are good to go!
BAN_M2C4180.00
      12-01-2016, 11:05 AM   #21
HP Autosport
Drives: F80 M3
bump
      12-05-2016, 06:22 PM   #22
HP Autosport
Drives: F80 M3
bump
m2
