07-06-2016, 05:18 PM | #1 |
Rep 542
BMS intake, CEL P120D
So does anyone know what this code means???
P120D It's happened twice with my BMS intake. BMS is unfamiliar with the code, and said they won't be able to assess until I get back to them with a description of this particular code So has anyone else had issues with the BMS intake??? Thanks in advance -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
07-06-2016, 06:08 PM | #2 |
Rep 2,523
I'm getting the same code. I had it cleared, but it still persists. I wonder if the M235i installs have had the same problem.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
07-06-2016, 06:10 PM | #3 |
Rep 2,523
07-06-2016, 06:15 PM | #4 | |
Rep 542
-c
07-06-2016, 06:58 PM | #5 | |
Rep 796
07-06-2016, 07:00 PM | #7 | |
Rep 542
I forwarded your info regarding the code to BMS, and the response was less than satisfying: BMS: I don't see how the intake could be related to a throttle position code. The throttle position sensor is in the throttle body near the intake manifold. The intake itself would have no effect on this sensor. Best, Jon BMS How about anyone here with a CEL email/contact BMS and tell them we are all getting the same code... Thanks guys -c
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock Last edited by pup73; 07-06-2016 at 07:31 PM.. |
07-06-2016, 07:25 PM | #8 | ||
Rep 796
07-06-2016, 07:30 PM | #9 |
Rep 542
Thanks. I admit it's a strange code. And this car is probably pretty finicky. However, I just think their response was a bit flippant, as if they didn't believe it could happen.
And I SWEAR, even before I knew what the code meant, this afternoon, while driving (CEL already present), I thought that the car was idling just a TAD bit rough. Since getting home from work, I have gone back to the stock airbox. CEL is still there, but the rough idle is gone. Again, I thought the car was idling rough BEFORE I knew what the code meant... Again, the price we pay for being impatient early adopters -c
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock Last edited by pup73; 07-06-2016 at 07:38 PM.. |
07-06-2016, 07:34 PM | #10 |
Rep 542
And you probably know this, but when installing, do NOT follow the PDF instructions. If you have a 6MT, you still do need to connect the vacuum hose to the intake, not leave it hanging and cap off the inlet hole on the intake, like BMS's instructions say. This was confirmed by another board member (I don't know how to post screen names), who also followed the directions, then contacted BMS when he got a CEL. However, we both have since installed the intake correctly, cleared the code, and in both cases the CEL returned.
-c
07-06-2016, 07:44 PM | #11 | |
Rep 796
07-06-2016, 08:15 PM | #12 |
BD_e92
358
Rep 1,748
I had that intake on my m235i and was getting the same code, switched back to stock and never got it again! Unfortunately a lot of these open cone intakes throw codes, BMS is not the only one from the m235 platform.
07-06-2016, 09:31 PM | #13 | |
Rep 542
Terry: I know a few M2 customers are running the intake and haven't received this fault code. Did you read the code with a BMW tool so we can see what it actually is? I suspect your OBDII description is incorrect. If it's a MAF sensor related fault then it would be intake related. I don't know how to reply; I'm simply giving them the code that has shown up twice now... -c
07-07-2016, 02:14 AM | #14 |
Rep 3,157
get a drop in filter, with the stock box and you'll be fine
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
07-07-2016, 05:14 AM | #15 | |
Rep 542
-c
07-07-2016, 09:52 AM | #16 | |
Rep 1,922
Drives: 2011 e91
Hearing about all these codes makes me want to sit back a bit and wait for companies to actually put some R&D time into their products for the M2. I don't want to be driving with the CEL on, mostly because it annoys me and also because I want to know if I get a code unrelated to the catless DP or the intake, i.e. fuel pump or injector or whatever. This CEL business on these intakes and DPs makes me sad
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
07-07-2016, 10:02 AM | #17 | ||
Rep 796
I wouldn't NOT but it. Just try and see how it works for you. I will be buying a new harness and trying again. I'm catless so the code is inevitable. I plan to flash tune once I move on the a bigger turbo. I'm not worried about it. |
07-07-2016, 10:07 AM | #18 |
Rep 796
I'm really hoping this is all due to the vaccum install error. Burger should really point this out in a new instruction manual.
That's the common factor between the two cars throwing this code. Hopefully mine doesn't. |
07-07-2016, 11:06 AM | #19 | |
Rep 542
And I did tell BMS about the faulty install, and they didn't mention that as a possible reason And I agree, they really gotta fix their instructions -c
07-07-2016, 02:05 PM | #20 | ||
Rep 150
07-07-2016, 05:11 PM | #21 |
Rep 85
Im in the same boat as you right now im running the catless downpipe with no Sim or tune and the code is tripped but it hasn't worried me too much. I might pick up the BMS can flap module to delete the CEL until a proper tune is released
2016 F87 M2 (current)
2019 Gt2 RS(current pipedream) 2016 Cayman Gt4(sold) 2010 E93 M3 (sold) 2012 Wrx Sti (sold) |
07-07-2016, 05:30 PM | #22 | |
Rep 1,922
Drives: 2011 e91
2011 E91
