07-10-2016, 01:44 PM | #1 |
Rep 276
Active Hybrid 3 MPE - No blurbles!
I have MPE on my AH3 since 2 weeks, sounds awesome but unfortunately it has no blurbles in Sport/Sport+.
So after watching some videos on Youtube of the AH3 with other exhaust systems, I notice these also won't blurble..not even a little bit. Mach 5 Remus Borla Attak I'll make a video of my MPE soon. F30 335i MPE: This got me thinking, and I believe these are the possibilities: - The AH3 has a different resonator (same as F34 GT) - - The AH3 also has a different Cat than 335i. - The AH3 is programmed in a way that it doesn't blurble, perhaps because it should be a quite hybrid. I will start with removing the resonator next week and post my findings in this thread. Second posibility: The biggest tuner in Belgium, BR-Performance, can also program the car that it will blurble. If the resonator delete won't help, that will be my second step. Last edited by frackje; 07-10-2016 at 01:50 PM.. |
07-10-2016, 02:53 PM | #2 |
Rep 3,622
The burble came with the MPPK and was made louder when used in conjunction with MPE
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
07-10-2016, 06:04 PM | #4 |
Rep 276
07-10-2016, 08:11 PM | #5 |
Rep 389
Drives: '13 F30 335i MSport
The problem is AH3. Not the same Beast!
2013 GSM 335i MSport
07-11-2016, 02:07 AM | #6 |
Rep 931
In the AH3 the burble (overrun feature) is disabled by software.
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
07-12-2016, 01:53 AM | #9 | |
Rep 931
Optimize also the performance !
07-12-2016, 02:45 AM | #10 |
Rep 4,526
Not a fan of overrun burble - AH3 without it sounds fine to my ears. Look on the bright side at least the wadding in your muffler will last a lot longer !!!
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
coolguy1o123.00 |
07-12-2016, 06:52 AM | #11 |
Rep 276
Maybe yes The first possible date is in september.
I think the overrun blurble sounds great!! |
07-12-2016, 07:41 AM | #12 |
Rep 931
Ok update the thread when available !
08-13-2016, 01:27 PM | #14 |
Rep 1,295
Did you decide to go with BR performance for a reprog in the end?
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
08-15-2016, 10:07 AM | #17 |
Rep 276
The AH3 has a different cat and midpipe so that could make a difference as well. I will try to get a hold on a GoPro to record the sound, really like the current sound. Sounds much heavier than a standard N55.
08-17-2016, 09:21 PM | #19 |
Rep 689
Drives: 22 TR X3MC
correct me if im wrong, but it sounds like the car gets to idle way too quickly compared to the normal 335i
2022 X3M Comp
2013 335i xDrive (Sold) |
08-17-2016, 09:54 PM | #20 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
I liked the Remus and Borla the most too
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
CIWS655.00 |
08-18-2016, 02:05 AM | #21 | |
Rep 1,295
Mechanically, the 335 and the AH3 have different engine flywheels, and I can't even find a twinmass flywheel part for the AH3 while the one for the 335i weighs 13kg. 335i http://www.etk.cc/bmw/EN/search/sele...CE/11/11_3187/ AH3? none? is that even possible? Eletronics may be programmed differently too and the engine ECU may be programmed to keep more boost in the 335 turbo by default.
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 08-18-2016 at 02:58 AM.. |
08-20-2016, 08:27 AM | #22 |
Rep 34
Active hybrid has an electric machine instead a torque converter. Also when letting off on decel it is regenerating the HV battery. I'd imagine this is why no burble.
