07-14-2016, 01:56 PM | #1 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Today's dyno run (376hp / 566Nm) and weight measurement (1582 kg)
This afternoon it was all about visiting my tuner and doing some measurements. The first task was checking the weight of the car!
In the end the car weighted in at 1582 kg with some papers, small gear and cables in my glovebox, but that was about it. I removed all the big heavy stuff. That would have acquainted for like max 500 gram in total. In the back of the car there we some spare lights bulbs for the car, the manual booklet and so on, another 500 gram. The fuel tank was 80% full which is about 42,5 liter, which is roughly 32 kilos. So let's deduct this from the 1582 and we get 1549 kgs for my spec car with fluids in the engine (oil, fuel, etc). Not too bad knowing that my car has a high spec and has a M-DCT. Secondly, we did a dyno run today. No tuning, only checking the output. The final output was 376 hp @ 6,500 rpm and 566 Nm @ 2,000 rpm. This is 6 hp higher and 66 Nm higher than the manufacturer says. Interesting! I am uploading a video now which will show the run. Exhaust note is bleh. I need a better sounding system. This sounds like nothing. Although I had my tuner drive my car and although he said it is a lot more civilized than the 1M, it sounded not too bad hearing him drive it on the industrial area. Also I had a short go in a 400 hp R56 MINI Cooper S... That was like W T F fast... MR |
07-14-2016, 02:41 PM | #4 | |
Rep 2,856
MR |
07-14-2016, 03:02 PM | #5 |
Rep 2,856
And the video:
07-15-2016, 08:01 AM | #7 |
Rep 2,856
08-19-2016, 08:57 PM | #9 |
Rep 3,888
