BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Vacuum Leak on Acceleration?
      07-21-2016, 11:56 PM   #1
ChuckyUK
ChuckyUK's Avatar
United Kingdom
16
Drives: BMW X1 xDrive25d xLine MW
Hi
I've had my X1 for 5 weeks now and it's been great. 3 weeks ago a noticed a whistle/air leak sound whilst accelerating. You can't hear this with all windows up but it's very prominent with the windows wound down . I'm wondering if anyone else is experiencing this noise ? The car is booked into BMW for next Thursday.
      07-22-2016, 12:57 AM   #2
Saintsman
Saintsman's Avatar
United Kingdom
40
Drives: X1 2.0i x-drive Sport AW
Is it just turbo noise Chucky?
      07-22-2016, 02:07 AM   #3
Les Paul
Drives: X1 2.0D Xline Auto
I get the same at about 1600/1800 rpm -only really noticable with the window down and under acceleration - I guess it is the second turbo cutting in, I used to get a similar noise on my petrol Audi turbo. There was another thread about this a while back, I think one poster got there turbo vanes replaced. I'll be interested to hear what your garage say. I've done about 8K and it's been there since new.
      07-22-2016, 03:29 AM   #4
CliveL
United Kingdom
163
Drives: 2016 X1 F48 xDrive20i xLine
Does the noise happen at all times in a trip, or only when the engine is warming up? The reason I ask is that there is mention in the technical documentation for the engine that suggests some noise when cold is by design as the wastegate valve is opened to allow the catalytic converter to heat up as quickly as possible:
Catalytic converter heating
When starting the combustion engine from cold, the wastegate valve is opened as wide as possible and the ignition point is adjusted to retard. The retarded ignition point delays the combustion process which in turn supports the heat input for heating of the catalytic converter. As the turbine housing is short, it has been possible to position the catalytic converter very close to the wastegate valve. As the exhaust gas flows into the catalytic converter at the perfect angle and because of its position close to the engine, the catalytic converter reaches its operating temperature very quickly. If the wastegate valve is opened when cold, pulsation of the exhaust gas may cause vibrations in the wastegate valve, which are perceived as noise. This is not due to a defective component, and is normal running noise. This noise becomes less audible as the temperature of the component increases.
      07-23-2016, 12:40 AM   #5
ChuckyUK
ChuckyUK's Avatar
United Kingdom
16
Thank for the responses guys. The car is showing 45.3mpg on the OBC over the last tank but according to my calculations has 39.2 mpg. That's quite a difference - so I'm assuming something is amiss! The hissing noise can be quite loud too. I understand your point about the engine warming up but the outside temp is about 26C so it shouldn't take long . It certainly is louder from cold and reduces with a driving but it's always there!!
      07-23-2016, 03:16 AM   #6
sdb123
Drives: F48 X1 M-Sport
Every BMW I've had has had variances of approx. 10-15% when comparing the Onboard computer to actual fuel consumption.
      07-25-2016, 01:53 PM   #7
dj_intrinsic
dj_intrinsic's Avatar
Drives: 23 G80 M3 6MT
Combination of turbo spool and e-wastegate. Totally normal.
2023 G80 MT / AW / Fjord Blue/Black | KW HAS | Apex VS5RS F:20x10+8 285/30-20 R:20x11+18 305/30-20 | Maxton Street Pro Splitter | OEM M3CS Grille | SST Valve Controller | CS Style Yellow DRL | MAD Non-Res Single Midpipe
Past: 2018 X3 M40i | 2016 M-Sport X1 | 2013 MT M-Sport 328i | 2021 Audi A6 Allroad
xbimmers
