08-01-2016, 04:13 AM | #1 |
Rep 170
Dealer can't get it fixed
Hi guys,
I own a January 2013 M135i. Posting in this forum as my doubt is related to the engine and not the model. I have detected that my car tugs (shakes forward, something like a power loss/normal power/power loss/normal power) when full throttle. Difficult to explain and even more if not native English. They have noticed that behavior when test-driving the car with me but they don't find the cause as no error is logged. Been searching and found that it could be due to spark plugs, injectors and/or coils. They have changed the spark plugs, air filters, fuel filters and microfilters at three year maintenance (BSI Plus), but problem is still there. Any idea on what can be the issue here? Thanks in advance! P.S. Car is stock except for the MPerformance Exhaust. Last edited by TitanNut88; 08-01-2016 at 05:26 AM.. |
08-01-2016, 04:37 AM | #2 |
Rep 603
Guess mine does it too:
At any gear (i.e. 2nd, or 3rd) going to like 4500 or 5000rpm keeping the throttle still, so rpm stays at the high rpm. Engine starts to shake. It feels like you describe, that the engine behaves "nervous". When I start moving the throttle (excellerating) the engine behaves normal again. I have to check once, if it also acts like that if in "normal" mode or just in "sport". So far I rated it as normal turbo engine behaviour and didn't put too much attention on it.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
08-01-2016, 05:21 AM | #3 |
Rep 7
Do you have any logging device? Might be hitting boost limit, just a thought.
F30 335i | Akarpovic Evo Exhaust| F30 EWG Specific| JB4 board with EWG Harness and flexi fuel wires| BMS Intake| ER Downpipe| ER Intercooler| ER Chargepipe| RennZport boost pipe| GFB Diverter Valve DV | Pure Stage 2 Turbo| Pure Stage turbo inlet pipe| Stage 2 Fuel-it LPFP| RennZport Thermostat| Fuel-it Platinum Tbi-Kit (Includes upgraded fuel lines and ethanol sensor) triggered via FSB| N20 plugs gapped @ 0.018"| N20 Tmap sensor| bootmod3
08-01-2016, 06:59 AM | #4 |
Rep 170
08-01-2016, 11:57 AM | #5 |
Rep 10,301
Did you dealer open or willing to open PUMA case with BMW in your country? In the US, these problems are shared with BMW North America (NA) and the dealer will work with BMW NA to determine what parts should be replaced next.
The dealer typically cannot replace parts under warranty unless there is a clear diagnostic path: an error code and known repair procedures. Otherwise, warranty repairs will not be reimbursed and prior approval from BMW (in your region) is required. Suggestion: - If BMW in your region agrees, replacing DME and wiring harness (there is more than one) from DME to major engine components might make sense. |
08-03-2016, 08:59 AM | #7 | |
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
08-04-2016, 02:49 AM | #8 | ||
Rep 170
BMW M3 Competition xDrive
Toyota GR Yaris |
08-04-2016, 01:12 PM | #9 |
Rep 4,323
have the dealer look at/test fuel pressure regulator, I suspect it's that.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
08-05-2016, 02:11 PM | #10 |
Rep 230
Play with ISTA+. You can get tons of live parameters, like accelerator pedal position, boost pressure, throttle valve position, air mass flow, spark misfires, injector info and so on
08-07-2016, 10:25 PM | #11 |
Rep 4,323
Have they run a full fuel diagnostic series? That can be a bad pump or fuel pressure regulator sensor.
08-08-2016, 02:29 PM | #13 |
Rep 141
My car used to do the same , and long story short the ended up changing. My turbo , it was leaking compression or something like that they really didn't explain end to me , I ask but the guy that work there didn't even have a clue about bmw cars. Lol
