08-04-2016, 10:11 PM | #1 |
Rep 29
JB Stage 1 with a catless downpipe and CEL fix adapter
Seems like everyone with a downpipe is using a JB4. I currently have a 2013 F30 335i (PWG) with a intake and JB Stage 1. I was going to get a ER catless downpipe mostly for the sound. I don't plan to race my car or use higher than a 91 octane (I live in shitty Cali) / E85 fuel or mess around with the different MAP settings.
Should I Just get one of those CEL-fix adapters after getting my downpipe installed, or is that just stupid and I should go all out and buy a JB4 to replace the Stage 1? Anyone else NOT using a JB4 with a downpipe? |
08-05-2016, 08:03 AM | #2 |
Rep 2,962
I'm not an expert but does the stage 1 have the ability to optimize the use of the downpipe? Meaning are you going to spend $3-400 on a downpipe and not be able to use it to its potential because of tuning?
08-05-2016, 09:19 AM | #3 |
Rep 29
That's the main question I have as well. I see many are running their JB4 with Map 2 setting which is +6psi and ideal for downpipe with 93 octane. I only get 91 octane and the Stage 1 is +3.5psi standard. Other than the obvious difference in psi I wonder if there's any other "optimizations" a JB4 will get me in my situation. I also have a PWG so I don't believe I can take advantage of the EWG features.
08-05-2016, 09:41 AM | #4 |
Rep 2,962
Is there a reason you don't want to get a JB4? I had stage one and ended up selling it for like $250 and bought a used JB4 for around $300. Even without 93/E85 I'd prefer the JB4
08-05-2016, 11:20 AM | #5 | |
Rep 5,776
08-06-2016, 04:57 PM | #6 |
Rep 71
I have stage 1 and downpipes on my car. Im not sure if the stage 1 utilizes the downpipes to its full potential, but I can tell you it runs better with the downpipes and sounds great. If you don't mind the CEL and smelling like a go-kart, go for it.
08-12-2016, 09:47 AM | #7 |
Rep 1,801
Curious as to how you liking this setup? Which brand DP did you go with and have you considered the Big Daddy mini cat CEL fix?
08-12-2016, 12:47 PM | #8 | |
BimmerPost Supporting Vendor
4922
Rep 115,999
You can always plug in the BMS CanFlap Module to take care of the CEL. Mike |
08-12-2016, 05:13 PM | #9 | |
24358
Rep 191,163
08-12-2016, 08:54 PM | #10 | |
Rep 262
Drives: 2013 BMW 335i M-Sport
08-13-2016, 01:18 AM | #11 |
Rep 29
08-13-2016, 08:56 AM | #12 | ||
Rep 2,962
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
08-13-2016, 01:27 PM | #13 | |
24358
Rep 191,163
VRSF do not have it listed on their website separate but i can get it for you
08-13-2016, 08:12 PM | #14 |
Rep 262
I'm thinking about going with a VSRF DP. How does the DP fix work? Also would I need to even worry about having the DP fix? I'm an area that has e-check so I just want to know I'm covered.
08-13-2016, 09:09 PM | #15 |
24358
Rep 191,163
I cant give you any advice on how to illegally pass emission tests, but the DP fix will trick your ECU into thinking that the cats are still there
08-14-2016, 12:28 AM | #16 |
Rep 1,801
08-14-2016, 12:54 AM | #17 |
Rep 5,776
Just saw that..yeah I want to know about this and hoping we get input from anyone who has used it and passed emissions--would well be worth the price compared to doing a DP swap.
08-15-2016, 12:22 PM | #18 |
24358
Rep 191,163
It will hide the code
